I can correctly unzip this version...!
Thanks,
Thanks,
Hi Mikael;
I get the message:
"No edit points could be relinked. You may have selected the wrong R3D directory".
I am pointing at the right place; although I have to make the 2 x point, because when I selekt the intire disk I get this message:
" find: /Volumes/Boxer 1//.Trashes: Permission denied".
And tell me where can I donate? :-)
Yours,
Christina
Looking at the XML you've sent, it seems you have renamed all your clips in FCP. But hopefully you've kept the movie file name unchanged so the script can read those instead...
beta 0.3 should fix that.
http://www.foolcolor.net/XML2RCX_0.3.zip
will look into the trash permission bug and get rid of it to for next version
Best
fixed in 0.31 :
http://www.foolcolor.net/XML2RCX_0.31.zip
I would recommend pointing to one or several folders where you know your R3Ds are located instead of a whole disk as it could be much faster if your drive contains a lot of non red files but it should now work without the permission error.
Thanks for the feedback !
0.41 now supports Avid XML...
only 1 layer will export for now, more to come soon on this (read the 1st post or read me file) :
http://www.foolcolor.net/XML2RCX_0.41.zip
Thanks for feedback on this if you test it...
new version 0.5 adds support for multi layer Avid XMLs, and will now export to bin with handles (or not) along with the timeline and whole clips to bin options...
http://www.foolcolor.net/XML2RCX_0.5.zip
Thanks Mikael! Your script rocks.
Great!!! I was just about to post a petition to have the footage to be located to both places!
Thanks a million!![]()
Hey,
I am using it for a feature, so I really do need it to have much more than 10 clips.
Thanks!
| Tags for this Thread |
