Thread: XML2RCX script (mac only)
Page 7 of 7 FirstFirst ... 34567
Results 61 to 65 of 65
  1. #61
    Could you send me the xml file and resulting lua by email I will have a look see if anything is wrong...
    Do you remember updating anything specific on your machine since it last worked ?
    Just emailed you. Only thing we have changed is RCX-Pro itself with the built in update tool.
    Thanks Mikael.
    Brandon Kraemer
    Editor / Colorist
    In / Out points look to be OK in the lua file relative to the XML values so I'd say maybe something is broken in recent RCX-PRO lua reading.
    I'll dig more see if I can reproduce the problem here but if you are in a rush to conform I can suggest :
    - try loading the lua in an older REDCINE-X version (even if you updated to the latest you should be able to manually download and run an older version) then you could always save the project and reopen in latest version.
    - give latest REDCINE-X PRO a new chance to read your XML, I have gotten good result not so long ago (it is true I did sent simple cut / silence edits)
    Quote Originally Posted by Mikael Lubtchansky View Post
    Mikael,
    The direct XML route works for us this time, I suspect it will usually continue to. Thanks for confirming it's likely something in RCX's LUA import tool. We would love to have options when it comes to this kind of workflow because in the past things like this come up and we need to try it a different way.
    Thanks again.
    Brandon Kraemer
    Editor / Colorist
    Glad it worked :-)
    will have a deeper look at this lua thing and hopefully will find time one day to merge all the useful tools into a cool and smart app !
Tags for this Thread
View Tag Cloud
