How can you use LivePlay with Teradek Cube Randall.
When I asked the LightIron team they said that you can view live images using Teradek Cube.
It's a bit involved, but worth it. You need a computer set up running live play server, and then the iPad running the LivePlay app, and the teradek cube with proxy recording setup, and all devices on the same wifi. When you record clips with the red, the teradek cube records the proxy file (with the same name and timecode as your original r3ds) on your computer running the live play server software. The iPad can then retrieve and play that recorded file. It does not stream live in the live play set-up. Which hasn't been an issue for us. We have on set monitors for that.
As of today this thread has had: Views: 116,589!! There is interest on this module!!
News on this one's pretty quiet that's for sure. I was wondering if they had decided that there are now enough other options on the market... despite all of us on here screaming about wanting an 'in-line' solution!
