Originally Posted by
Marin
When you load the clip in the Rushes and set your render options (debayer quality, color space, gamma, etc.) and your resizing options, go to Output, make sure you select Quick Time in "Output Format", then check "Burn In" check-box and select what information you want to be rendered onto or "burned-in" the clip. You have 4 drop-down menus where you can specify what you want burned-in. From your first post I think you definitely want "Reel/Filename" selected as one of the options.
