Thread: Lots of Lenses & RED Accessories
Results 1 to 5 of 5
  1. #1 Lots of Lenses & RED Accessories
    Senior Member Billy Mead's Avatar
    Jun 2008
    I have over 50 lenses posted and more coming. Most are older, manual focus still lenses & all have been prepped for cine-use with step-up adapters, UV Digiclear Filters and Metal front caps. Some even have metal focus gear. There are few PL mount lenses (Arri 40mm, Leica 50mm, Pelang 8mm) and more coming.
    Also, we have over 100 RED Accessories. I have posted some last night but the bulk will be put up over the next day. We have a lot more coming included mounting hardware, cables galore, etc. etc. Don't buy new until you've checked these out as all auctions are NO RESERVE. I will continue posting gear later today.
    http://shop.ebay.com/filmstarequipment/m.html
    Best always,
    Billy
    Film Star Rentals
    Shoot, Edit, Compose
    www.filmstarrentals.com
    Banned
    Jul 2008
    Texas
    Impressive. So many to watch.
    Great stuff Billy. Too bad you won't do international. Good luck on the sales!
    Steven-Marc Couchouron
    SMC Productions
    Jun 2008
    Hi and thanks for the comments. Just added a load more online, especially RED Accessories. I also have a box full of RED cables to add and will later tonight/first thing tomorrow. http://shop.ebay.com/filmstarequipment/m.html
    As well, we have a warehouse full of lighting and grip that is being sold off now. Tungsten, HMI and florescent fixtures galore... and almost ever piece of grip equipment imaginable from apple boxes to zip clips and everything in between. I will slowly be adding everything to eBay but only 100 pieces at a time. If you are looking for L&G this is a great time to buy and save big!
    A few stand out items:
    • DIVA 400 Kit (1 left)
    • Filmgear 2 and 4 bank, 4 foot fixtures (Kino clones but very well made. Can give you references from people that have purchased and are very happy. uses same tubes and comes with egg-crate, separate ballast, head cable and custom flight case.)
    • 15' Manned Crane (holds an operator, breaks down into 4 flight cases and will fit in an SUV. Check it out here: http://www.filmstarrentals.com/ccp0-...aneRental.html
    • Visual Engineering Platform Dolly/Jib Combo. Custom built, very well made of aircraft aluminim. Rides on heavy duty Matthews track.
    http://www.filmstarrentals.com/ccp0-...l-eng-jib.html
    • Vance Jib - Probably the best built fulcrum jib we've ever seen. Holds 55 lbs. set-up in minutes. Includes heavy duty tripod with 3 sets of wheels, weights, and pelican case. http://www.filmstarrentals.com/ccp0-...vance_jib.html
    • 20 & 30 lb. Remote heads. Joystick controlled, perfect for use with 18' Jony Jib below:
    - 20 lb. Version: http://www.filmstarrentals.com/ccp0-...t_jonyjib.html
    - 30 lb. Version: http://www.filmstarrentals.com/ccp0-...Jonyjib30.html
    - Remote Zoom/Focus controller for above: http://www.filmstarrentals.com/ccp0-...omcontrol.html
    • 18' Jony Jib - Industry standard, very heavy duty telescoping Jib. Breaks down into a 4' Pelican Case. Very complete, http://www.filmstarrentals.com/ccp0-...t_jonyjib.html.
    • Omni-Tracker Table Top Dolly. Award winning dolly for very fluid table top shots... includes laser sight. http://www.filmstarrentals.com/ccp0-...ckerDolly.html
    • Bogen 529B Mini Tripod for above (or stand alone) http://www.filmstarrentals.com/ccp0-...iniTripod.html
    • Custom Built Car Tow Dolly. You don't see these come up often for sale. has two sets of wheels, we have towed everything from Corvettes to SUVs. http://www.filmstarrentals.com/ccp0-...rTowDolly.html
    • Chinese made HMI's. Before you laugh, check them out. ARRI clones but well made. I can provide references of people that have purchased them and saved a bundle. Just before closing down we bought 20 fixtures and they are BRAND NEW, never used... and check the prices! As a rental company we really did our research and needed to get reliable gear. We were very impressed and put them though their paces. So while it may seem 'too good to be true', give me a ring and I'll introduce you to the compnay. There are the 4th largest lighting manufacturer in the world, employ 300 people and are a ISO 9000 manufacturing company.
    • 2.5K HMI PARS - ARRI Clones, need lenses & scrims (will take standard size sets) - BRAND NEW, the ballasts never even had plugs installed. $2500 each, SAVE THOUSANDS and then the laughing stops...
    • 4K HMI PARS - ARRI Clones, need lenses & scrims (will take standard size sets) - BRAND NEW, the ballasts never even had plugs installed. $3000 each.
    • 575 HMI PARS - ARRI Clones, comes with a set of 4 HMI PAR Lenses - BRAND NEW, the ballasts never even had plugs installed. $1275 each.
    • over 200 Different used Mole-Richardson Fixtures...
    I could go on but if you are looking for grip, mounting hardware, speedrail, overheads, butterflys, scrims, stands, carts, distro, cable, sounds, audio, microphones, headsets, or almost anything else... at last drop me a line!
    Best always,
    Billy
    Film Star Rentals
    Jun 2008
    Also, we have over 200 different 4x4 and 4 x 5.65 Glass Camera Filters... let me know what you are looking for!
    Film Star Rentals
Tags for this Thread
View Tag Cloud
