Click here to go to the first RED TEAM post in this thread.   Thread: How to Shoot my Segment.
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1 How to Shoot my Segment.
    Currently I get jobs to work on segments of larger programs where other crews have been used at other locations. Often they send tapes to show me the lighting/camera movement/composition style which has been established.
    Let's say the show has been shooting using HDCam/Varicam so far on other locations around the world.
    The producer is going to show up with a Sony/Panasonic set up card and ask me to set up the camera we are using here to match the other cameras used previously in the show.
    Now for my RED Setup.
    I put the camera in reduced sensor mode and mount a S16 zoom to get similiar depth of field to whats already been done.
    I set the RED at the established frame rate. Set output to RGB 1080 or 720 set interlaced or progressive as has been done so far.
    I take the Sony/Panasonic set up card to my computer. which has REDCINE loaded, place the set up card in the reader and?????
  2.   Click here to go to the next RED TEAM post in this thread.
  #2
    You point the existing camera as set up to a macbeth card, and generate an image. You do the same with RED and tweak until it looks the same. Sony setup files don't work in Panasonic cameras or software, as they're proprietary. You don't just need to know the values, but the exact algorithms that they determine, which are secret and won't ever be known.
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    Graeme's approach is the practical one. It is not just that Panasonic and Sony are incompatible. There are significant differences in menus and settings between the F900/3 (also known as the F900H) and the F900R, for example. Plus that way you avoid STDs (Settings Transmitted Diseases).
    Senior Member Finner's Avatar
    sounds like when the camera comes out a few people will be able to test, compare and create some sony or panasonic LUT's that match specific cameras. This would be great as people could post here what they have found and different users could send each other the LUT they need and bingo you have a match.
    www.finnerknowsbest.com
    "There are many dying children out there whose last wish is to meet me." The HOFF
    "you'll be hearing a lot about me over the next couple of decades." The JohnathanLB
  5.   Click here to go to the next RED TEAM post in this thread.
  #5
    Yes, that's right Finner - it's a reverse engineering process and your suggestion would work great.
    Graeme
    Graeme or Finner
    Could you clarify how one writes a look up table and how one puts it into the camera, or are we again talking about rendered output from the computer?
    MIke: This has come up with us on different cameras also. It sometimes won't work unless you have the exact same model/series camera.
    This is a big pain, since it causes the producer to specifiy a specific cameramodel and series. So if you buy a brand new Sony F900R. They may still force you to shoot with an older version where it will match? better?
    TJ
    www.camera-person.com
    TJ Williams
    Seattle WA USA
    206 769 8585
    RED1, 4K Sony HD (HDCam) Panasonic HD
    Operator Dp, Videographer
    Steadicam Camera Crane Aerial mount
  7.   Click here to go to the next RED TEAM post in this thread.
  #7
    Once we've got it locked down, I'd love to tell you the precise details of how it works!
    However, it's more than just a lut, as that only covers tonal changes, but also a 3x3 matrix which governs camera transforms. Manipulating them can require either a great deal of time, or of expertise (or both).
    Graeme
    "Manipulating them can require either a great deal of time, or of expertise (or both)."
    Graeme
    I hope not!!! as you may be able to tell from my posts I'm not terrifically comfortable with computers. I've set upSD/HD cameras but it was just look at the monitor tweak the menus. Look at other setups that have been done or
    just insert the card and push load.
    On a Sony/Panasonic just insert the card and match! Setup is not completely crazy either, set from the menus save to card. It will be very much appreciated here if I can just load a lut fm someone who sets it up by attaching to the computer and hiting UPLOAD. thereby giving my RED the LUTs look in the output.
    TJ
    TJ Williams
    Seattle WA USA
    206 769 8585
    Senior Member Nick Shaw's Avatar
    London, UK
    I think Graeme's taalking about the detailed internal workings, which the user does not need to worry about. I assume REDCINE is an easy to use interface to this complexity, and what I hope is that you can use REDCINE to define a look, then save that as a setup which can be uploaded to the camera.
  10.   Click here to go to the next RED TEAM post in this thread.
  #10
    Yes indeed Nick!
    Graeme
