Thread: 12x12 Overhead question: Single black or double black net?
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 12x12 Overhead question: Single black or double black net?
    Hi there all. . .
    . . . quick question.
    I have a 12x12 frame and currently have a white silk, a single white net, and a double white net.
    I was wanting to add a black net of some sort to use to knock down windows and for overhead lighting control, but I only want to buy one of them. Which one is likely to prove more useful? The single black (0.6 stops) or the double-black (1.2 stops)?
    My original thought was to buy the single and to use two. . . the single white on top and the single black underneath, but I'm not sure if that makes any sense or not.
    Any thoughts?
    Thanks.
    Stephen
    RED One M-X "Lewis" (#791)
    First feature film, Works in Progress, out on DVD (Vanguard Cinema).
    Second feature film, Terminal, now in post-production in Kansas City and scheduled for a late 2013 release.
    Third feature film, Dust, currently in pre-production and scheduled for production during summer 2014.
    Jun 2009
    Hi Stephen,
    In the 12x12 size, if you were only to buy one new rag, I think a 1/4 silk would come in handy in more instances than a single or double net. It's nice if you want to do an overhead and want to take the intensity of sun down a touch but you think a full silk is too much.
    But as with everything, you need different tools for different situations, and everyone has a different approach to any lighting situation.
    Oct 2008
    Gorham, Maine
    if it were my decision, I'd go for the double. I often use a double net over a practical window, where it's a lot less fussy than gel, and almost always invisible. In that situation, a single isn't often enough. I have never doubled up a white and a black, but I expect you'd see it if you used it on a window that appeared in a shot. Also, if you double two black singles, you get moire. Again, I don't know for sure if that would be a problem with a white and a back, but I'd want to test it before committing the cash.
    David Fuller
    AirStream Pictures
    RED ONE #172MX
    EPIC-M #1053
    Jan 2007
    Double for windows. I use single + double lot in bright light. It's hard to know exactly because different windows may have different coatings applied. Houses are often clear but commercial buildings are often treated where I am.
    For overhead I like a single but I want the light quality to change so it would be a silk. Also, painters clear drop plastic is pretty good if you're not worried about sound (music videos?).
    Then a double it is. . .
    Yeah, I doubt if I could use a white and a black both on a window, but I like the slight softening effect that a white gives me on an overhead for a beauty shot outdoors, but it's the darn windows I'm mostly after.
    Joel. . . a clear plastic sheet? How would that work?
    Thanks guys!!!
    Stephen
    Senior Member Charles Angus's Avatar
    Jun 2007
    Toronto
    I've used "clear" plastic sheets on windows I'm planning to blow out, and it's looked great.
    I would go for a double net in your case.
    Charles Angus Taylor
    www.charlesangustaylor.com
    Too funny, Charles. . .
    I'm not sure what he was referring to the clear plastic, but I'm guessing it must have some sort of a tint to it. I'm sure it's cheap, so I'd love to know what it is and how to use it. These days, cheap is my friend.
    Stephen
    Jun 2007
    Toronto
    The clear plastic I'm talking about is sold in huge sheets at the hardware store as "contractor-grade painting dropsheet". In appearance, it is similar to hilite or maybe opal (it's been a while). I double it up, usually.
    With that stuff over the windows, it doesn't matter what's outside - it all just goes white. And the quality of light inside is gorgeous.
    Nov 2008
    Get the double net and then an ultrabounce or grifflon and you'll be set.
    KIP KUBIN
    Aaton Film Cameras
    Lomo Square Front Anamorphics
    Cooke Primes and Zooms
    For darkening windows, a double -- a single only cuts down light by a half-stop, a double by one-stop (and generally if you are going to go through the trouble of gelling a window, most people start with ND.6 or ND.9, which are two and three stops). What's nice about a double net is that it not only takes some of the hotness down (just a bit though) but it softens the view. And it doesn't ripple in the wind like ND gel can...
    David Mullen, ASC
    http://www.davidmullenasc.com
