Thread: RED Rocket 30-bit HDMI out to Dreamcolor
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1 RED Rocket 30-bit HDMI out to Dreamcolor
    Senior Member Curran Giddens's Avatar
    Jan 2007
    Berkshire County, Massachusetts
    Changes since last release:
    • RED Rocket Breakout Box HDMI output
    • PsF monitor out fix
    • Stability improvements
    Looks like the HDMI out is now live. If anyone gets a chance to test it with the HP Dreamcolor please post here.
    May as well go through a Red Rocket Breakout box instead of an AJA converter box. Plus, you never know when you might need to hook up a 4K display. :-)
    http://www.SolarSystemStudio.com/
    EPIC-M #508, EPIC-X #124
    Are we sure bit depth out of HDMI from breakout box is 30 bits? If so ... that's a pretty big deal -
    Senior Member Johnny Friday's Avatar
    Feb 2007
    La Paz, Baja Ca. Sur, Mexico
    i was going to suggest the same thing. I can't recall seeing that in specs--from what little i had seen of specs and hence the reason i pulled trigger on the AjA converter.
    John Friday
    La Paz, B.C.S., Mexico
    www.bajaproductions.com
    EPIC M & 2X for 3d & Deep Epic Underwater Housing
    RED MX with SSD & Underwater Housing
    Jan 2007
    Rob? Deanan?
    What are the specs for the HDMI out on the Breakout Box?
    If you say it's 10-bit I will order one straight away....
    Quote Originally Posted by Mark L. Pederson View Post
    It is supposed to be once fully implemented. Deanan said in the past that for the 10bit HDMI we would need the BOB. HDMI is now enabled... :)
    Now I wonder, will the RRBOB give me better HDMI than what I get from the Rocket HD-SDI going through an AJA Hi5-3G converter? How is the BOB enabling HDMI? My gut feeling is that the BOB is doing HD-SDI to HDMI conversion as well. Otherwise, I don't see why we could not have a lower-cost cable option right out of the RED Rocket to give us 10bit HDMI....
    - Jeff Kilgroe
    Jan 2007
    Yeah, I was assuming they were doing conversion from HD-SDI too just like an AJA box. That is why I never pulled the trigger on an AJA. The Red Rocket BOB is a bit more expensive, but you never know when you may need to hook up a 4K display.
    the BOB and SDI out only work with playing R3D files, right?
    So working in Smoke or Resolve and adding to the RED footage (like adding a mask or doing a composite) would not out put via the BOB or SDI from the RR?????
    Just trying to figure out what the value of having SDI or BOB from RR is apart from if you are only doing dailies or transferring to tape of just your RED footage.
    Rory Hinds
    Director / DoP / Colourist
    Mine Films & Mountain DI
    http://www.minefilms.com
    UK, USA, CANADA, EUROPE & SOUTH AFRICA
    IATSE 669 Director of Photography
    VFX, Grading & Finishing
    Jan 2007
    Quote Originally Posted by roryhinds View Post
    Right.
    Right. Smoke or Resolve (when they support it) just use the Red Rocket card for debayering. The rest is done on your GPU and monitored using the display connected to your computer.
    If you don't need to hook up a display directly to the RR or have the extra HD-SDI outputs then you don't need the BOB.
    Think of it like an AJA converter but specifically for the RR with the added ability to hook up a 4K display. Keep in mind some of the other options available (nVidia $$) to hook up a 4K display to your computer. Also, it isn't all that much more than an AJA box. And most importantly, it would look way cool in the rack.
    Jan 2007
    I emailed my rep when I ordered the Red Rocket BOB. This was the reply:
    From what I have been told, the HDMI outputs should support both 8-bit and 10-bit now.
    I have never hooked up my Dreamcolor to a 10-bit source. How do I know if I am getting the full deep color?
    Senior Member Andrae Palmer's Avatar
    Aug 2007
    Fort Lauderdale, FL
    Any one tried this and can convert 10 bit support?
    Andrae Palmer
    Founder, FACETMEDIA LLC
    facebook.com/facetmedia
    Package for rent in South Florida with EPIC-X Camera #721 & RED One #6353, RPP, RED Rocket, RED 18-50 & Oconnor 2575C. Davinci Resolve, FSI LM-2461W & Mac Pro 12 core. Rentals/Equipment List: http://facetmedia.com/red-rental/
