Click here to go to the first RED TEAM post in this thread.   Thread: RED Format Resolutions
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1 RED Format Resolutions
    I am just trying to find out the exact resolution to the RED formats. If any of you could fill in the blanks that would be cool:
    4.5K = 4520 x 2540
    4K = 4096 x ?
    2K = 2048 x ?
    1080P = 1920 x 1080
    720P = 1280 x 720
    480P = 720 x 480
    Just 4K and 2K I am not completely sure of due to seeing different numbers being listed on different websights. Thanks.
  2.   Click here to go to the next RED TEAM post in this thread.
  #2
    4.5K or 2540p = 4520 x 2540
    4K = 4096 x 2304
    2K = 2048 x 1152
    1080 & 720 numbers are correct (as was 4.5K)
    We do not support 480 (NTSC) or 576 (PAL). HD and up only.
    There are various 4K & 2K resolutions in use. It depends on aspect ratios and a couple of other things. Since our sensor has a 16:9 shape the vertical resolution for 4K & 2K is 4096 and 2048 divided by 16:9.
    In post you can crop that to other 4K & 2K "standards" or any aspect ratio you want / need.
    ROBCODE Santa Claus @ RED
    "You get the chicken by waiting for the egg to hatch, not by smashing it with a hammer" - Jarred
    Thanks. I did not mean to put 480P, but just out of habit I did.
    REDuser Sponsor Brook Willard's Avatar
    Burbank, CA
    Rob, what is the full sensor resolution? I'm referring to the 4.9K overscan... 4900x2580? I know it can't be captured.
  5.   Click here to go to the next RED TEAM post in this thread.
  #5
    Yes, 4900 x 2580. I wouldn't really use the term overscan for it though.
    Burbank, CA
    Look-around?
  7.   Click here to go to the next RED TEAM post in this thread.
  #7
    Look-around uses the 4.5K area
  #8 Max frame size
    Red Team Stuart English's Avatar
    Irvine, Ca
    Rob is correct 4520 x 2540 is the max area, and its used for look around when you are shooting 4K, 2K, 1080p, 720p etc...
    The pixels outside this maximum imaging area are matted off so that no light can illuminate them. Then we use their output to perform an automatic black level compensation - which you typically need to do manually on a professional level 3 chip CDD camera.
    Workflow Wizard
    Wow Stuart that is very clever. So the red camera is automatically black balanced at 7.5ire at start up?
    TJ
    www.camera-person.com
    TJ Williams
    Seattle WA USA
    206 769 8585
    RED1, 4K Sony HD (HDCam) Panasonic HD
    Operator Dp, Videographer
    Steadicam Camera Crane Aerial mount
    Jan 2007
    Melbourne, Australia
    Quote Originally Posted by tj williams View Post
    One would hope 0IRE (or whatever the digital equivalent is), since RED doesn't speak SD...
