Thread: green footage
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1 green footage
    REDuser Sponsor Brian D. Goff's Avatar
    Switzerland
    I have all the new plug-ins and updates, still my MX footage is green in Premiere Pro CS5. What am I doing wrong?
    Thankx
    Brian D.Goff
    Owner/Chief Designer ActionProducts
    DoP
    www.actionproducts.ch
    info@actionproducts.ch
    ShowReel (DP/ActionCam)
    www.brian.goff.ch
    EPIC-X with Electras & co, Leica R 15mm to 560mm Primes and Zooms
    Senior Member Kim Frank's Avatar
    May 2009
    To me this sounds like corrupt frames that cause the green images and make it impossible for the software to read the file. Only way I know is to transcode around the corrupt frames to DPX with redrocket.
    I hope someone knows another cause for this issue.
    Otherwise I'm really getting concerned of the mass of posts on this board about corrupt frame issues.
    @RED: like I stated before... I can't believe that suddenly al our CF card readers, drives an cables went bad. It's time to take it serious IMO
    Director/DP/Writer
    Hamburg - Germany
    http://www.vimeo.com/kimfrank
    Switzerland
    Quote Originally Posted by Kim Frank View Post
    Frames are ok, looks good in REDcine and QT, so it seems to be a PP problem.
    Brian D.Goff
    DoP
    www.brian.goff.ch
    May 2009
    Glad to hear that...
    Hopefully someone can help you
    Director/DP/Writer
    Hamburg - Germany
    Are you using the latest plugins from Adobe? Any time MX files are viewed with software coded for the original M chip, the image has a green tint to it.
    Clint Johnson
    http://clintjohnson.com
    Original Owner RED One #351
    Part owner of RED Epic-X
    Switzerland
    Quote Originally Posted by Clint Johnson View Post
    I reinstalled the plugins - no works:)
    Brian D.Goff
    DoP
    www.brian.goff.ch
    same here.
    I don't know what to do.
    Olivier
    #MX2070
    Paris
    The frenchie doc
    Switzerland
    Quote Originally Posted by Olivier Madar View Post
    same here.
    Olivier
    Hi Oliver
    I solved it by removing the beta plugins, and then reinstalling them. Also remove the QT plugin and reinstall it too.
    Brian D.Goff
    DoP
    www.brian.goff.ch
    Jul 2007
    same here.
    Olivier
    Encode to codec that your NLE can read for the time being if you are in rush
    Quote Originally Posted by Brian D. Goff View Post
    Hi Oliver
    Thank you,
    I will try that.
    Olivier
    #MX2070
    Paris
    The frenchie doc
