Click here to go to the first RED TEAM post in this thread.   Thread: Audio Drifts From Picture
Results 1 to 7 of 7
  1. #1 Audio Drifts From Picture
    Senior Member Mark B.'s Avatar
    I recorded footage at 29.9xx fps and the audio is drifting further and further from the video the longer it plays. Is there a setting somewhere in RedCine to correct this problem?
    Senior Member jimhare's Avatar
    Sep 2007
    Sydney Australia
    Are you in an editor (FCP/AVID) when it drifts, or RCX?
    RCX (build 321). Win7 64 bit. There's the "audio->auto match->rate override" menu, but changing the rate of the audio isn't quite enough to push the audio into keeping up with really long video footage. Also, it seems like the audio is always lagging the video by a couple milliseconds, from start to finish. It's that way even on shots where the actor is immediately near the camera, so it's not an issue of sound wave delay to the microphone. It seems like the RedCine could use an extra setting to allow audio to be offset overall. And probably a more precise option for tweaking the audio speed. I'm sort of wondering why the audio is mismatched to begin with, like it seems that maybe there's a bigger problem in the software when it comes to the audio data.
  4.   This is the last RED TEAM post in this thread.   #4
    Bender Matthew Yaeger's Avatar
    Sep 2009
    Southern California
    Is this issue only showing up with playback in the app or is it also showing up in your transcoded clips?
    I'm running version 326 now, and I'm not getting any sound at all in the transcoded clips.
    Quote Originally Posted by Mark B. View Post
    Are you doing a complete transcode, or aborting them before completion - if so, you will get pictures but no audio.
    Director/Digital Camera Operator/2nd AC/DIT/Data Manager
    London, UK.
    Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.
    I'm doing a complete transcode but the audio still doesn't show up in the resulting file.
