Thread: How do I get the gritty look with the RED ONE?
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Jul 2009
    Quote Originally Posted by Andrew Wilding View Post
    Yeah, alien skin is really top notch in that regard. Even the scratches and dust options look incredibly real.
    we should petition Alien Skin to make a motion version of Exposure for FC, AE, Color etc etc. I cant see why it wouldn't be easy as pie for them to port it, since motion is just a series of stills, after all. I'd be the first in line, without a doubt. Exporting things to image sequences and running them through photoshop is just too tedious to be an option.
    To mere mortals like you and I it seems straightforward. If it's available in PS, then why not in AE? Unfortunately they're both built using different SDKs so it's a case of their starting from scratch - and also knowing about the particular needs of moving images, which in a computer is more than just an image sequence.
    I've been talking to Photomatix about porting their HDR prog to AE (it is available as a plug-in for Photoshop) and they say it can't be done and the only way to use it for video is currently to batch process in the stand-alone version. Or, I would guess, in PS CS5.
    Back to the thread's main subject - take a look at the Varicon to get a desaturated image in camera - I posted on another forum here about it.
    Senior Member Andrew Wilding's Avatar
    Oct 2008
    I'm keeping hope alive. : )
  3. #13 lomos
    Mar 2008
    As others have suggested, I love older glass as a starting point. Lomos have a smoothness that's really nice. If you're in LA you can look at my set. I would consider Cooke S2/Speed Panchro too.
    Morgan
    Senior Member christopher witzke's Avatar
    Mar 2009
    Louisville/Cincinnati/Nashville/Indy
    I did a Music Vid last year and ended up exporting out an image sequence of still tiffs to a folder... opened one, and recorded an action in photoshop and then batch processed the folder for all of the frames.... then imported the folder back into quicktime and saved as a prores movie... then dropped that clip over the original for the audio. Turned out pretty decent and only took a few hours.
    Senior Member Jarek Zabczynski's Avatar
    Poughkeepsie, NY
    Magic Bullet Editors has grain that looks decent. It doesn't offer too much control, but not bad.
    Shoot for the Impossible...Then do it.
    Jarek Zabczynski
    Director / Editor / Cinematographer
    Epic X - #5515 | www.jarek.com | WE'LL BE ALRIGHT (Music Video) | INCREDIBLE (Scarlet Music Video)
    Senior Member Pietro Impagliazzo's Avatar
    Mar 2008
    Rio de Janeiro, BR
    You won't match 35mm grain without heavy post-processing. A plugin that would look at each pixel and simulate how a grain structure would see it would be the best bet, not sure there's an advanced plugin for that.
    Research and check if shooting 2-perf isn't what would suit your project best. Underexposing Kodak 500T by a bit can give you a nice gritty look.
    Test, test ,test.
    Acintyah khalu ye bhava na tams tarkena yojayet
    There's no use arguing over that which is inconceivable
    Pietro Impagliazzo
    vimeo.com/impa
    impagliazzo.500px.com
    Senior Member Kim Frank's Avatar
    May 2009
    Quote Originally Posted by christopher witzke View Post
    I havn't worked with this option in other ways to just export some frame grabs, but in PS CS5 you can import movies. Alien Skin looks really great! Isn't it possible to apply it to the movie and render it out in PS?
    I will give it a try...
    Director/DP/Writer
    Hamburg - Germany
    http://kimfrank.net
    Senior Member Scott Miller's Avatar
    Jul 2009
    Carlsbad, Ca - San Diego/OC
    Maybe someone will write a plugin that leaves line 1, then skips 2,3 and 4, leaves line 5..... well, you get the idea:)
    Epic-X #1763, "Phase III"
    Ti PL & Canon EOS mounts, suite of EOS glass, O'Connor 1030 & 515 support available for rent & shooting.
    Moved on to new operator:
    Red #6732, "Dunsmore"
    (Dunsmore, Scottish Heritage)
    www.squawthedocumentary.com
    www.projectarbiter.com
    Oct 2008
    Quote Originally Posted by Kim Frank View Post
    I wonder if the grain would "randomize" if you just batch processed or applied it to a movie. I'd worry that the same grain pattern would be applied to every frame. When I used it on A still sequence I adjusted the grain settings ever so slightly on every frame. It paid off.
    Senior Member Zakaree Sandberg's Avatar
    orange county/los angeles
    i got some kowa cine primes that give the organic older look
    Zakaree Sandberg
    Zakaree@Gmail.com
    Cinematographer / Local 600 DIT
    RED MX - 1015
