Thread: Anyone using LTFS with LTO-5?
Page 6 of 6 FirstFirst ... 23456
Results 51 to 58 of 58
  1. #51
    Junior Member
    Mar 2013
    When you say "Use the command line "unltfs" command to clear a tape:" you don't mean on one of my good tapes with all my data surely? Do you mean with a blank tape?
    I tried the command with a blank tape and it throws back this message:
    dyld: Symbol not found: _UCNV_TO_U_CALLBACK_STOP_4_0
    Referenced from: /Library/Frameworks/LTFS.framework/Versions/Current/usr/lib/libltfs.2.0.0.dylib
    Expected in: /Library/Frameworks/ICU.framework/Versions/Current/usr/lib/libicu.40.1.dylib
    in /Library/Frameworks/LTFS.framework/Versions/Current/usr/lib/libltfs.2.0.0.dylib
    Trace/BPT trap
    Is there something missing from my Library?
    Senior Member Tim Jones's Avatar
    Dec 2008
    Scottsdale, AZ, USA
    No - I meant to do that with one of your questionable / bad tapes.
    However ...
    Quote Originally Posted by Ces T View Post
    Trace/BPT trap
    That is indicative of a bad LTFS driver installation. The specific error indicates that the ICU package hasn't been properly installed (why it's needed, no one can tell me other than it was part of IBM's original source files). Check your DMG that you installed LTFS from and make sure that you install the ICU package.
    Tim
    Tim Jones
    brumeister - www.productionbackup.com
    Junior Member
    Mar 2013
    Sorry to keep asking questions, you're being so helpful! Where do I find the LTFS driver installation? Is it part of my HP tape drive or is it an LTFS system that I need to get from somewhere?
    Dec 2008
    Scottsdale, AZ, USA
    You'll need to download the package from the HP site. I can't direct link because of the way their servers do links, but this is the top page that you'll use to get to the downloads:
    HP LTFS Downloads
    Tim Jones
    Junior Member
    Mar 2013
    Ah, ok, so is it the StoreOpen Standalone software?
    Dec 2008
    Scottsdale, AZ, USA
    Correct. The "open source" file is the source code and even I have problems compiling that hodge-podge of source (and I've been at this stuff since 1978 ).
    Tim Jones
    Dec 2008
    Scottsdale, AZ, USA
    Quote Originally Posted by Tim Jones View Post
    Also, I forgot to mention that it also means that your existing tapes are probably okay and will be recoverable using ltfsck after you get the drivers restabilized.
    Tim Jones
    Junior Member
    Mar 2013
    Excellent, you were absolutely right! So it seems I can now mount all my old tapes fine (except the latest) and the StoreOpen app works as it should. That's one HUGE relief. Now it's back to the issue that triggered all of this to begin with, because my last tape won't mount. StoreOpen says this in the logs:
    Mount volume
    LTFS9015W Setting the locale to 'en_US.UTF-8'. If this is wrong, please set the LANG environment variable before starting ltfs.
    LTFS14000I LTFS starting, LTFS version 2.0.0, log level 2
    LTFS14058I LTFS Format Specification version 2.0.0
    LTFS14063I Sync type is "time", Sync time is 300 sec
    LTFS20013I Drive type is HP LTO5, serial number is XXXXXXXXX
    LTFS17160I Maximum device block size is 524288
    LTFS11005I Mounting the volume
    LTFS12015I Attempting to load the medium
    LTFS11026I Performing a full medium consistency check
    Entity: line 1: parser error : Document is empty
    13780100925805C14E56080046020226
    LTFS17037E XML parser: failed to read from XML stream
    LTFS17016E Cannot parse Index (direct from medium)
    LTFS11194W Cannot read Index: failed to read and parse XML data (-1014)
    LTFS11220E Medium check failed: extra blocks were detected on the medium. Please run ltfsck.
    LTFS11027E Cannot mount volume: medium consistency check failed
    LTFS14013E Cannot mount the volume
    LTFS20076I Triggering drive diagnostic dump
    LTFS20096I Diagnostic dump complete
    LTFS session finished
    This is what happened initially: I successfully wrote two Mac Finder folders to the tape, checked them back, all good, deleted originals from the Mac. In another session, I started writing another batch of folders when it threw up some kind of error, something about write failed. So I went through the usual procedure of un-mounting and ejecting. It was after this that the tape stopped mounting. The first batch of data is not backed up anywhere else, so it's critical that I retrieve them, I'm not bothered about the rest.
    So I've just tried typing the command usr/local/bin/ltfsck 0 --full recovery but I got this:
    Ces:~ ces$ /usr/local/bin/ltfsck 0 --full-recovery
    LTFS16000I ltfsck starting, LTFS version 2.0.0, log level 2
    LTFS16014I Checking LTFS file system on '0'
    LTFS16023I LTFS volume information:
    LTFS16024I Volser(Barcode) :
    LTFS16025I Volume UUID : 93c8865c-d116-432f-a0cd-1ae1d6efa815
    LTFS16026I Format Time : 2013-03-15 17:25:43.397929000 GMT
    LTFS16027I Block Size : 524288
    LTFS16028I Compression : Enabled
    LTFS16029I Index Partition : ID = a, SCSI Partition = 0
    LTFS16030I Data Partition : ID = b, SCSI Partition = 1
    LTFS11223I Generating lost and found directory
    LTFS11230I Writing Index(es) to restore consistency
    LTFS12047E Cannot write file marks: backend call failed (-1). Dropping to read-only mode.
    LTFS11082E Cannot write Index: write file mark failed (-1)
    LTFS11031I Volume mounted successfully
    LTFS11032I Unmounting the volume
    LTFS11033E Cannot unmount: failed to write an Index
    LTFS16022I Volume is consistent
    Ces:~ ces$
Tags for this Thread
View Tag Cloud
