Click here to go to the first RED TEAM post in this thread.   Thread: Export Error (CINE-X 339)
Results 1 to 10 of 10
  1. #1 Export Error (CINE-X 339)
    Junior Member
    Apr 2010
    Hey guys,
    I have a problem with REDCINE-X 339 and the export options.
    When I go to the export settings with the "+" button and choose the QT format I can`t use the "Setup" button beside it. I can click the "Setup" button (and it turns orange) - but there is no popup menu as with tiff or other formats.
    Is there a way to solve this problem?
    btw: I`m using Win7 (64bit).
    Thanks a lot!
    Mo
  2.   Click here to go to the next RED TEAM post in this thread.
  #2
    Bender Matthew Yaeger's Avatar
    Sep 2009
    Southern California
    Please make sure you have QT installed on the machine.
    Junior Member
    Apr 2010
    Of course it is ;)
    Norway
    But is QT-pro? (that means basically: FCS)
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    Junior Member
    Apr 2010
    Mh.
    No Final Cut (...on the PC), no Quicktime Pro.
    Is QT-Pro absolutely necessary?
    Norway
    It used to be to encode quicktimes.
    It is so long ago I didn't have it, that I don't know, but I'd think so.
    Looks like that is still the case:
    http://en.wikipedia.org/wiki/QuickTime
    Twitter: gunleik
  7.   Click here to go to the next RED TEAM post in this thread.
  #7
    Sep 2009
    Southern California
    It does not require the pro version of qt to get the dialog to show up. The only time we have seen the dialog not show up is when QT is not installed. Please turn on verbose logging and try to open the dialog again.. then send the RCX log file to redcinex at red dot com.
    Norway
    Good to know.
    Twitter: gunleik
    Junior Member
    Apr 2010
    okay, I`ve used the form at the left on http://www.red.com/support to report the error. Hopefully that`s okay, too.
  10.   This is the last RED TEAM post in this thread.   #10
    Sep 2009
    Southern California
    Problem is fixed for the next release and is the same as the issue in http://reduser.net/forum/showthread.php?t=50897
