Click here to go to the first RED TEAM post in this thread.   Thread: In-Camera "Looks"
Results 1 to 8 of 8
  1. #1 In-Camera "Looks"
    Jul 2010
    Is there any plan of adding features that allow us to replicate for example the look of certain film stock in camera?
    Of course, you could throw it all away afterwards due to the RAW workflow, but it would be nice to be able to see in real time what the image will look like.
    Senior Member Bastien Tribalat's Avatar
    Dec 2009
    Nice, France
    I suppose you can tweak a lot the settings in cameras (with gamma curves and stuff like that) so you can get a bot cloer to the film stock you want to look like (if you do you setting based on how are they on the film stock... I know Kodack provides that kind of stuff on their brochures).
    Am sorry I have no other answer for your question but I hope that helped a bit.
    VIDEO EDITING - COLOR GRADING - VFX
    APPLE FINAL CUT PRO, APPLE COLOR, AVID MEDIA COMPOSER
    ADOBE CREATIVE SUITE, DAVINCI RESOLVE, REDCINE X PRO...
  3.   Click here to go to the next RED TEAM post in this thread.
  #3 Filmstock "look"
    Red Team Stuart English's Avatar
    Irvine, Ca
    Experiment with REDCINE-X, and when you fins a look you like, export that to the camera as a .RLK file.
    Workflow Wizard
    You can make a look that might suggest a closer representation - but to see (with respect to color) what a film stock looks like - you need a 3D LUT - which will restrict and map certain colors as they appear on that film stock.
    If you want to view the live signal with an actual film emulation lut for a specific stock - you can do this with a DAVIO for example. Or, a monitor that accepts 3D LUTS like a Cinetal, etc.
    But the nice thing about shooting RAW is to not get forced down the road of "critical color monitoring" on set. When you shoot film - you don't do critical color monitoring on set.
    Senior Member Mark Phelan's Avatar
    Oct 2007
    Quote Originally Posted by Mark L. Pederson View Post
    Good observant comment.
  6. #6 How about a Looks module?
    Feb 2010
    Twin Falls, Idaho
    Quote Originally Posted by Thomas Church View Post
    I say a Looks Module that would accept Looks via SD cards or wi-fi, designed by Red Cine-X or other software red's or third party's would.
    this module would save lots of time for ENG and the like kind of work. oh and with pro connectors please. or even better include it in the brain as an option. but I would have to be able to see the results in the LCD.
    What a film stock looks like is pretty subjective -- most stocks are negative, so what we see is a positive copy or conversion that has gone through some degree of gamma change and color-correction, so it's the look of the negative stock + the look of the print stock and how it is timed, or the look of the electronic positive version of the negative image.
    In other words, just play with the settings to create a look you like, whether or not it happens to be similar to your opinion of what 5219 Vision-3 Kodak looks like.
    I've never really understood these programs to make video look like a film stock -- it's so apples and oranges, both from an acquisition standpoint but also from a viewing standpoint. To me, it seems like a shortcut to thinking about the look you want to create, those "instant" pre-programmed looks. I mean, what's so hard about playing with the color saturation, gamma, and black levels to create a look?
    David Mullen, ASC
    http://www.davidmullenasc.com
  8.   This is the last RED TEAM post in this thread.   #8 LOOKs ingest
    Irvine, Ca
    You already have that function - it's called the .RLK file on SD Card / CF Card.
    Workflow Wizard
