Click here to go to the first RED TEAM post in this thread.   Thread: R3d convert to .exr
Results 1 to 6 of 6
  1. #1 R3d convert to .exr
    Trying to find the easiest solution to convert .r3d files to .exr (openexr) files. Is this just a matter of rewrapping or is transcoding required. We need to keep all of the camera originals 10 bit log information through the post workflow.
    Thank you for your help.
    Norway
    Redcine-X?
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    Perfect. Thank you!!!
    Norway
    Twitter: gunleik
  5.   This is the last RED TEAM post in this thread.   #5
    In REDCine-X you can export R3D to EXR. EXRs are always exported linear light, with lens-cap black at 0.0f, and based on the ISO/Exposure/FLUT you select, 18% mid grey will be mapped to 0.18f in the EXR.
    If you export an R3D via REDCine-X to REDLogFilm, you will find that based on the ISO/Exposure/FLUT you select, 18% mid grey will be mapped to code value 470 in the 10bit DPX you create.
    You can also use the Lin2Log node in Nuke to go from EXR to equivalent REDLogFilm via it's default settings, and also from a REDLogFilm export to linear light in Nuke via Log2Lin, again with default settings.
    Hope that helps Paul, and it sounds like the EXR / REDLogFilm workflow is right for your needs.
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    Norway
    Thanks Graeme for explaining the workflow.
    We will run tests on this now!
    G
    Twitter: gunleik
Tags for this Thread
View Tag Cloud
