Thread: RedRocket encoding acceleration
Results 1 to 5 of 5
  1. #1 RedRocket encoding acceleration
    Banned
    Nov 2010
    Hi,
    its my first post here so I will start with a little bit of dumb question.
    Right now we are encoding 4k R3D files to ProRes HD 4444 .mov files with RedRush using RSX settings. RedRocked card isn't present in the system.
    The process is a unacceptability slow at MacPro v4.1 8 cores.
    Will the RedRocket card help us to go faster encoding ?
    thanks
    Norway
    Yes. Simply put. A lot.
    If you are transcoding r3d's from build 30 firmware or later, you should not use rushes anyway. Clipfinder will get you the right image for rushes.
    And welcome!
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    With an 8 Core MacPro you're probably getting 3-4 Frames Per Sec. of encoding speed. A RED Rocket will turn that into 24 FPS, realtime encoding!!!!
    If you do a lot of shooting a Rocket will be the best $3000/$4750 you'll ever spend.
    - Jan
    Director/Editor
    www.jbalster.com
    https://vimeo.com/user486354
    Banned
    Nov 2010
    Jan,yes 3-4 frames per sec without camera RSXs and 1 frame per 2-3 sec with RSX loaded.
    Thanks for inputs guys!
    Junior Member
    Nov 2010
    Got banned for reason not using real name,my fault.
