Thread: Connect to mac by cable Firwire 800 / 800
Results 1 to 6 of 6
  1. #1 Connect to mac by cable Firwire 800 / 800
    Banned
    Nov 2010
    Hello all
    it's my first topic at red world ...
    I can't connect by cable. Firwire 800/800 to my MacBookPro and Hard Drive
    I tried more than Cable
    When I use Firwire Cable 800/400 it's connected
    400 out of Hard Drive
    800 in to MacBookPro
    Can explain where is the Problem ???
    Note:: I don't Know where I create this topic
    Senior Member Eirik Tyrihjel's Avatar
    Oslo, Norway
    Hi and welcome, it´s a common problem that the firewire 800 port gets short circuited - the risk of this happening seems to be a lot higher if the drive is not powered by a separate powersupply.
    Yours sounds a lot like the FW 800 port on the drive is short circuited, if you want it fixed it would have to go back to RED for repair I suppose.
    I have had one of my drives like this for almost 2 years, I just kept on using it, offloading via the fw 400 port.
    RED EPIC-M #646, EPIC-X #250, Scarlet-X P/L #2467 "Harbor", RED ONE #476 MX "MOTHER"
    Commercials | Live | Concerts | Corporate | RED rentals
    Red Pro Primes T1.8: 18,25,35,50,85,100 (all metric), red CF zoom 18-50 T3 (imperial), Red Pro Zoom 17-50mm T2.9 (metric), Red zoom 50-150 T3 (metric) + 300mm T2.8 (imperial) + tons of accessories!
    Leica Summilux-C series on order.
    www.groovyentertainment.com/english/
    Whether you think you can or think you can't - you are right. ~Henry Ford
    There seems to be a issue using some reddrives over firewire800 connecting to the new unibody macbookpro . The solution is to use a lexar fw800 reader in between. Use preferably external powersupply on the Reddrive.
    Filip Vandoorne
    RED Digital Cinema rental & consultancy
    Epic-X #391 and #2975 with Ti PL and Ti Canon mount
    RED One MX#1391
    RED Pro Primes, RED Zooms, Duclos 11-16, Leica R sets cinemod's for Canon mount
    www.therightmix.be
    Apr 2008
    Washington DC Metro Area
    Quote Originally Posted by Hossam View Post
    Hello all
    Well you have two good answers, but both assume that you are asking about a RED Drive.
    Are you using a RED Drive or is this some other type of drive enclosure?
    Alexander Ibrahim
    Director & DP
    editing/color correction/compositing/effects
    http://www.alexanderibrahim.net
    http://www.zenera.com
    Banned
    Nov 2010
    Thanx a lot for your attention
    Eirik Tyrihje , Filip Vandoorne and Alexander Ibrahim
    Alexander Ibrahim ...
    I using the red drive and this problem happened by all of my red drives only
    but when i connecting to G-saffe or G-raid it's successfully
    I guess if I use the Power Adaptor which included by RED-DRIVE maybe success connecting but i fear that be a bad solution or damaging red drive.
    Are you advice me to use this Power Adaptor when I connecting to MAC BOOK PRO by FW800 Cable ?
    Senior Member Jody Neckles's Avatar
    Oct 2009
    London
    Yes I would LOVE to have an answer about this.... Perhaps someone from RED can comment?
