Click here to go to the first RED TEAM post in this thread.   Thread: Red Rocket - NO OLPF or Noise Reduction
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
  1. #11
    Feb 2009
    San Juan, Puerto Rico
    It is kinda depressing to know that a 5000 dollar card can't do proper finishing. Even worse is that I have two of them. Also, the guys from Filmlight (makers of Baselight) told me about many of their clients feeling the same way about the rocket.
    ________________________________________
    Frank Cueto
    Reaktor Post & Transfer
    Baselight Color Correction and DI, DaVinci Film Transfers (S35,35,S16 & 16) & Tape to Tape
    Smoke Advanced & Smoke HD ON-Line Suites
    (3) GFX/VFX Suites
    (2) Final Cut Pro Suites with HD-SDI Monitoring and IO
    ProTools 5.1 HD Suite, with HD-SDI monitoring/IO,recording booth & FX-Music Libraries
    (2) On-Set workstations powered by RED Rocket™ with 16TB RAID 6 storage & Dual-ESata CFReaders
    Senior Member roryhinds's Avatar
    Jan 2007
    Vancouver, BC, Canada
    I guess it does what it does and thats fast turn around low quality transcoding (but still high enough quality for most people) and for Finishing work you're better off having a render farm type system so spend the money on some more CPU's then on the Rocket.
    That is certainly where I'm heading, I'd rather have a faster CPU (X5680) then get the Rocket as it doesn't do what I need it to do for my Finishing work.
    So does Resolve, Scratch and Filmlight all use the Rocket for interactive work then switch over to the CPU for final rendering/transcoding? Or are people just using the Rocket transcoding as the best they can get without going to CPU processing for optimum quality?
    Rory Hinds
    Director / DoP / Drone Pilot
    Mine Films & Mountain DI
    http://www.minefilms.com
    UK, USA, CANADA, EUROPE & SOUTH AFRICA
    IATSE 669 Director of Photography / Drone Pilot
    VFX, Grading & Finishing
  3.   Click here to go to the next RED TEAM post in this thread.
  #13
    Rocket is sharp enough demosaic to not need the OLPF compensation in RC-X, indeed, I don't often recommend it's use - it's something best done at the end of the processing chain. Similarly with the NR, which is just chroma BTW, which is quite nice in RC-X (Mike Seymour seems to love it) but again, not a necessary thing as most shots don't need it, and if they do need NR, the NR tools in the finishing software are usually up to the job.
    Graeme
    www.red.com - 8k Digital Cinema Camera
    Science enables stories. Stories drive science
    IPP2, Image Processing, Colour Science and Demosaic Algorithms
    Senior Member Peter Moretti's Avatar
    Apr 2008
    Graeme,
    I'm sorry, I'm not sure if you are saying that when using a Rocket card the noise reduction settings in RC-X are used or aren't used?
    Thanks.
    1110001100010102
  5.   Click here to go to the next RED TEAM post in this thread.
  #15
    There's no chroma NR on Rocket.
    Graeme
    Mar 2009
    As something of a neophyte, I'd like to try my understanding here...
    ROCKET is suited well to being used for the quick production of offline files due to it's realtime ability to transcode RAW into a variety of filetypes from RCX.
    High quality finishing work may be done with the online files after editorial when there is more time for the CPU to do its work though whatever finishing app is being used, since the ROCKET will not provide OLPF compensation and/or chroma NR.
    Correct?
    Wait, Rocket transcode isn't finishing quality? Since when?
    OK, it doesn't have noise reduction or OLPF compensation, but the Debayer is full resolution and potentially useable for cinema quality finish otherwise right?
    DOP / Digital Lighting Camera Operator
    London, UK.
    Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.
    Jan 2007
    I think thats just it Eric, for Cinema Finishing you'll want to do a CPU transcode/debayer to get the optimum quality from your footage which your finishing tool can work with.
    Rory Hinds
    Feb 2009
    Eric, I haven't used it for finishing yet, I have been using it for dailies mostly every day.
    That said, I recently had a long chat with people who have tried to use it for finishing, in an environment where every lil bit counts, and they decided that the quality of the debayer isn't exactly the same and that the CPU debayer does look better. They reckon that red might have to skimp out on somethings of the algorithm to get realtime debayering.
    Wanna chime in Graeme?
    Frank Cueto
    (3) GFX/VFX Suites
  10.   Click here to go to the next RED TEAM post in this thread.
  #20
    The Rocket demosaic isn't necessarily better or worse than the software one - they're different. Rocket is sharper naturally, so no need for the OLPF compensation control, but also, a tad noisier. It's a tradeoff, and again, it's designed for hardware realtime, whereas the software one can be more flexible via it's software nature.
    Graeme
