Thread: WorkFlow Problems!!
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1 WorkFlow Problems!!
    Dec 2009
    New York City
    1. What is a DPX?
    2. Where can I find the program Clip Finder?
    3. What's the difference between EDL and XML?
    4. I am looking into buying a computer and was how many gigs of RAM are best plus processor in the ballpark of $1,500 for MAC. Any suggestions? Is it worth getting the RED rocket?
    5. Organization question -- What's the best way to organize RED footage or files before color grading? Can the files be re-named as shown on the slate or would that screw up the files or connections to the proxies? If not, what's the best way of doing it?
    6. After organizing, how should we edit the proxies on a final cut timeline?
    7. We did edit proxies without organizing and it was a mess. Then we output to XML, imported into Red Cine X, build 351, color graded to our liking, but we are lost on how to export to a full quality sequence. Do we export in RED Cine as one timeline and then drop it into Final Cut into the timeline with the Proxies? Or is there a way to relink the proxies with the color graded raw files for a full quality export? This is where we are lost.
    8. It also seems when editing proxies to XML, certain effects don't apply -- for example, widescreen, vignette, and slow-mo. How do we make these effects possible when we color grade on XML?
    9. If we do export to a pro-res first, how do we relink those to the raw files for a color grade later?
    1) http://lmgtfy.com/?q=DPX
    2) http://lmgtfy.com/?q=Clipfinder
    3) http://lmgtfy.com/?q=EDL+XML+difference
    4) When pushing anything with more resolution than Standard Definition MiniDV, you would be wise to max out the RAM for whatever computer you are buying. If you have a need to transcode Red R3D files to any other video format for editing or hand off to a client, rather than editing natively in Premiere Pro or Avid or another Red native capable NLE, then the Red Rocket will save you A LOT of time.
    5) It's best to leave all the rushes file and folder names the same when importing into your NLE. You can rename within your NLE for convenience, or just enter the slate information in another field of the metadata.
    6) 7) 8) 9) Suggest you try reading up on Final Cut Pro/Apple Workflow in this forum and other forums.
    Director/Digital Camera Operator/2nd AC/DIT/Data Manager
    London, UK.
    Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.
    Dec 2009
    New York City
    Thanks Eric!
    Nov 2008
    Quote Originally Posted by Dominick Sivilli View Post
    If you're doing a lot of RED work, the Rocket will be a lifesaver. Depends on what you're doing, though.
    Never, EVER, EVER rename your files. You'll cause yourself more trouble than any time you'll save. The "standard" procedure is to just dump each card into its own directory, which you can label as suits you. Most folks just use "Card #1", etc. But you can date them, or whatever you like. But don't rename the files.
    You can rename the footage in your NLE to your heart's content. Just don't change the filenames.
    Well, in my opinion you're missing a step. Editing with the camera proxies is (despite its inclusion in the whitepaper) not a recommended workflow. You'll have less trouble if you render prores proxies from RedCine-X or Clipfinder (This is where the Rocket helps) and editing those.
    This is really a matter of preference. Mine is to grade in Color or DaVinci rather than RC-X, but if you want to grade in RC-X, you've got a number of options. Given your later question (I'll get to it in a sec) you're probably better off rendering your graded files as individual ProRes files, then using Clipfinder to reconform your XML to the rendered files, taking it back into FCP for final output.
    You don't. The FX may be included in the XML, but RC-X doesn't support them. Which is why I suggest rendering individual ProRes masters and conforming in FCP, so you can apply your FX to the final footage.
    Clipfinder. Either the free version, if you want to grade in Color, or the paid version if you want to grade in RC-X. There are other ways, but clipfinder is by far the easiest and simplest.
    Senior Member paulherrin's Avatar
    Oct 2008
    Johnson City, TN
    It seems as though your current expertise lies elsewhere. I would consider hiring some assistance for now, and if you are trying to get in to this field of work, training is required.
    The RED has probably the simplest professional digital post-workflow I've ever seen, but it is a professional workflow and a professional tool - some basic understanding of post-production is probably a prerequisite.
    But please feel free to ask these questions and learn, there are some really knowledgeable and generous guys around here who are happy and willing to answer them all. I only worry, with these types of questions, that you're currently ill equipped to handle the task without further instruction.
    Kind of like when you get a question about the DVD player from your parents, you can talk them through getting a disc to play, and the best they can do is write down exact notes - but you know they're never going to be able to do anything more advanced with it on their own. It's the same here, you have to have the experience and the discipline that comes with it in order to really understand and use a thing in a creative way.
    Best of luck.
    Senior Member Jeff Coatney's Avatar
    May 2007
    Fushun, China
    Dominick, "Problems" are just "opportunities to learn". On the upside, you are going to be the newest Red Workflow Expert!
    Apr 2008
    Washington DC Metro Area
    Maybe I misunderstand... but I'd expect to spend $6500 for a Mac for serious editing and post as a starting place.
    $1500 is WAY off the mark.
    I'd buy the current 8-core Mac Pro with 8GB of RAM from Apple ($3649) Its not the fastest... but its the sweet spot for price performance. (Arguably the 6 core 3.33GHz is very competitive in price performance.)
    (Normally I do not recommend Apple's memory upgrades, but in this case ordering the upgrade opens up 2 slots as well as buying more RAM- so its worth it.)
    I'd add Crucial's 8GB RAM Kit (2 4GB sticks) for just under $200.
    To that I'd add an i/o card. For economy and features I'd point you at a BlackMagic Design DeckLink Extreme 3D... that's $995 MSRP
    That's already $4844
    This ignores adding hard drives. (which I also recommend you don't do through the Apple store.)
    If you want to work with RED footage in anything near real time then I recommend upgrading the graphics card to the fastest available Nvidia card, and using Premiere Pro CS5 as your NLE.
    Alternatively, a Rocket is a good idea.
    The fastest current Nvidia Card is the Quadro 4000, at around $900. You can get most of the performance of that card in the GTX 285, which runs about $500 (on Amazon)
    All this ignores the cost of software.
    Final Cut Studio is $1300 or so.
    Adobe Production Premium CS5 is $1700 or so.
    So like I said... $1500 seems way off the mark for a Mac for post work.
    Alexander Ibrahim
    Director & DP
    editing/color correction/compositing/effects
    http://www.alexanderibrahim.net
    http://www.zenera.com
    Junior Member
    Dec 2009
    Long Beach, CA
    Quote Originally Posted by Alexander Ibrahim View Post
    Well said, not counting extra storage, the least I was able to get for what I needed (a RED capable PC with CS5) was closer to 6k.
    Nov 2008
    Quote Originally Posted by paulherrin View Post
    Paul pretty much nailed it with this. And it applies to the computer purchase too. RED is pro-level and requires pro-level hardware. Is it possible to get a machine the will work with RED footage for $1500? Yes. You could go ahead and buy a 13" Macbook Pro, the small iMac or a Mac Mini. Will it be *GOOD* at working with RED footage? No. You *might* be able to find an older Mac Pro on Ebay for under $2000, but is it really worth it? You'll probably end up with the same performance as one of the aforementioned machines. Plus the fact that, hardware aside, the *software* breaks your stated budget.
    Oct 2008
    Johnson City, TN
    there are other options for hardware (i.e. "hackintosh" or windows)... i build all of my computers, and they are just as good, and WAY less expensive than getting it from the apple store. there are drawbacks to that of course, and we don't need to start a whole discussion about that, I just wanted to state that there are other options to get closer to the performance you need at that price. you'll probably need some help with that if you try to go that route, don't just order a bunch of hardware and expect it to work together.
