Thread: Multiple GPU vs Rocket
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1 Multiple GPU vs Rocket
    I don't know if anyone has had a chance to test this or not, as the update just came out, but I'm curious about performance differences when grading R3D footage if you were to use 2 CUDA GPUs (and one GUI GPU) vs 1 CUDA GPU and 1 Red Rocket (and one GUI GPU)?
    Thoughts? Tests?
    Thanks,
    -Alan Gordon
    Post Pro Gumbo
    Senior Member jake blackstone's Avatar
    Nov 2007
    Debayering is performed by CPU not GPU, which means, that increased number of GPUs doesn't affect that aspect of the process.
    Senior Member Robert Horwell's Avatar
    UK
    so when grading red footage and already having a RR installed what are the benefits of the multiple GPU?
    EPIC M & X / RED MX / ALEXA .
    "If you want to be free just be free, do not ask anyone.
    You must have a hypothesis of your own fate and follow it without submitting yourself and by ignoring the circumstances". Andrei Tarkovsky.
    Senior Member N_Villers's Avatar
    Jan 2008
    Budapest, Hungary // Vermont, USA
    Everything but the debayer.
    Nov 2008
    To answer the implied question in the OP, and build off what everyone else has said:
    If your projects are primarily RED footage, you'll get better results with a single processing GPU (That doesn't include the GUI GPU) and a Rocket. Like Jake said, Debayering isn't sent out to the GPU(s) at all, so you're either doing a CPU debayer or a rocket debayer.
    Multiple GPUs will only help *after* the debayer, which is probably the most intensive step in the whole chain. So if you're speccing a system, I would suggest GPUx2 (One for the GUI) and a Rocket as the initial step. If you've got the cash, GPUx3+ Rocket.
    Nov 2007
    I guess, it is a sign of times, where with 3x FX4000 GPUs and RR it's possible to grade 4k images in real time with $1k software on a Mac.
    Can't quite display it though...
    UK
    thanks,
    so i have 2X gtx 285 gt120 and RR.
    anyone know if prem pro will make use of the gtx285 even though its not being used as the gui gpu?
    Thanks all! Seems like my originally spec'd system is still the way to go. I'm all about the R3D.
    Maybe soon I'll have another GPU or two and maybe an additional RR to really be doing it real time, but for now it seems 1 GPU, 1 RR, 1 GUI will do.
    Now just to figure out how to monitor all this...but that's another can of worms for another thread.
    Anyone tested performance of GTX 285 vs Quadro 4000? Shame on Apple, why they didn't get us GTX 580 / Quadro 5000/6000 support...
    Quote Originally Posted by jake blackstone View Post
    Or play it in real time unless you also have a very, very fast disk array. Or play real time through dissolves unless you have a very, very, very, very fast disk array.
