Click here to go to the first RED TEAM post in this thread.   Thread: EasyHDR on hold...
Page 5 of 13 FirstFirst 123456789 ... LastLast
Results 41 to 50 of 122
  1. #41
    Aug 2009
    Pāhoa, Hawaiʻi
    Quote Originally Posted by CJ Roy View Post
    Perhaps a simple toggle to A/B the over/under?
    I'd be down with this.
    Senior Member Joel Arvidsson's Avatar
    Nov 2008
    Sweden
    Does the software recordnice the two streams automatically or do you have to choose one stream first and then "find" the other one and choose it?
    Or even better, does it show up as one file?
    Norway
    Quote Originally Posted by Joel Arvidsson View Post
    Just guessing here, of course, but they would/should have the same reel and clip name, but probably have a naming that doesn't conflict with A/B 3D shooting...
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    I'm not sure if this was covered elsewhere, but what's the practicality of processing HDRx? Can this be handled by the current rocket card?
    Thanks.
    San Diego, CA
    Having EasyHDR at some point down the road will be a nice addition to the tool set, even if it doesn't get used much. I fully support Jim and the RedTeam moving this feature to the back burner in the short term.
    Cheers - #19
    Member Sami S's Avatar
    Sep 2007
    Tampere, Finland
    How does this effect Scarlet fixed? As I understood Scarlet Fixed was only going to get eHDR.
    Senior Member Antonio Forjaz's Avatar
    Jun 2009
    Maputo, Mozambique
    easyHDR seemed to me a more non-professional tool...
    Antonio "Pipas" Forjaz from Maputo, Mozambique
    EPIC X #943
    RED MX SSD #6340
    www.pipasforjaz.com
    www.mahlafilmes.com
    Apple Certified Pro FCP 6 REDucation MX edition completed
    Senior Member keith morton's Avatar
    Mar 2009
    Los Angeles, CA
    I'm cool with that.
    EPIC-M 529
    Senior Member michael zaletel's Avatar
    Apr 2008
    Phoenix, AZ
    In a really dark scene, is it possible to flip the standard behavior to protect the deepest shadows instead of the highlights? Or am I not understanding correctly.
    Please advise,
    -michael zaletel
    Quote Originally Posted by Jannard View Post
    EPIC-X/M max HDRx™ frame rate is 5K at 48fps (or 60fps at 2.35:1). Since it uses twice the frames as normal, cut max rates in half.
    Does this mean that HDRx on the Epic-S, which you said in another thread supported about half the data rate of M and X, will be limited to 24 fps at 5K and 30 fps at 5K 2.35:1?
