Thread: DAVINCI RESOLVE and ***HACKINTOSH***
Page 23 of 60 FirstFirst ... 1319202122232425262733 ... LastLast
Results 221 to 230 of 595
  1. #221
    I am sorry: I have three 470s, not 460s. I can't change the case because I am only allowed to use the machine as is because it will also serve double duty to run Windows for CUDA programming using a mobile rack for the system drive (one drive for Windows, another drive for me to use Mac OS).
    If you have some time in the coming weeks for a custom configuration, I would greatly appreciate it.
    Senior Member David Kellermann's Avatar
    May 2009
    Freiburg, Germany & Prague, Czech Republic
    Hi Luigi,
    I wanted to update to Lion using your Machete installer, but saw in the description that I have to have my Areca in slot 4 and the Blackmagic 3D+ ind slot 2. Unfortunatly, my Areca is in slot 6 and the Blackmagic 3D+ in slot 4. Since I connected my GPUs (in slot 3 5 7) with a watercooling bridge, I can't change the slots of the other cards without removing the GPUs. Do I have to modify your installer in any way to use it with my setup?
    David
    a better TRUTH . commercials & workflow management & aerial cinematography
    Germany | Czech Republic
    http://www.a-better-truth.com
    Have a look at my last short-film and vote for it, if you like it!
    Partner @ Short of the Week
    Senior Member luigivaltulini's Avatar
    Oct 2009
    Switzerland- LUGANO
    Quote Originally Posted by David Kellermann View Post
    Hi Luigi,
    David
    ciao David.
    certainly made ​​to feel that we organize a remote desktop ;) or try new installer see down post ;)
    thanks
    Luigi
    Oct 2009
    Switzerland- LUGANO
    ciao,
    little update at MACHETE installer,
    added at the new installer can select 3 nvidia GPU, with the other free slots, and 2 NVIDIA Quadro GPUs"this is in beta test".
    3 gpu is:
    slot:
    1. free
    2. free
    3. nvidia
    4: free
    5: nvidia
    6: free
    7: nvidia
    for 2 quadro 4000:
    slot:
    1: free
    2: free
    3: quadro 4000
    4: free
    5: quadro 4000
    6: free
    7: free
    choose the amount of GPU you want in Lion , step after installed on the boot partition.
    https://rapidshare.com/files/52784098/machete2.zip
    thanks
    Luigi
    Could you perhaps try this little benchmark?
    http://forums.creativecow.net/readpost/277/8355
    The yousendit link doesn't work, but email the guy to get the file.
    Also any status on the GTX 570?
    I've had a go at trying to get the 570 working on a system here. However OpenCL works, CUDA works, but the "video player" inside davinci doesn't work. Adobe Premiere CS 5.5 has the same issue in fact.
    Oct 2009
    Switzerland- LUGANO
    Quote Originally Posted by Jimmy Christensen View Post
    Ciao Jimmy
    this is my result:
    V1 2 nodes : 24 fps
    V2 4 nodes : 24 fps
    V3 6 nodes : 24 fps
    V4 12 nodes :24 fps
    V4-x2 24 nodes: 17 fps
    V5 NR 4 : 24 fps
    V6 NR 4 : 24 fps
    V7 NR 4 : 24 fps
    V8 NR 4 : 12 fps
    You have a ASUS p6T7 Supercomputer?
    strange because it works for me,
    maybe you have another motherboard?
    thanks
    Luigi
    Wow, impressive numbers :)
    I have ordered one.
    However my theory is that it's mainly because I use the GTX 570 as main display card aswell.
    Oct 2009
    Switzerland- LUGANO
    Oct 2009
    Switzerland- LUGANO
    ciao GUYSSSSS..
    Update 10.7.1:
    Added patch at machete for 10.7.1.
    - OPENCL
    - APPLE AUDIO OUT HDA
    - CHAMELEON 1348
    simple procedure, update to 10.7.1, reboot, open Machete and select 10.7.1 + chamaleon , repair permission and reboot ;)
    https://rapidshare.com/files/464801124/Machete2.zip
    thanks
    Luigi
    Oct 2009
    Switzerland- LUGANO
    Public photos of a hack for Davinci RESOLVE in Russia. I managed to run two NVIDIA 4000, with some initial difficulty APM power management, not easy in remote desktop to patch dsdt ,but then everything went wonderfully well;)
    ALEXANDER Thanks you for your patience.
    Really great performance.
    ASUS P6T7 supercomputer mainboard
    2. Nvidia 4000
    1. areca 1222
    1. highpoint
    1. blackmagic 3d
    thanks
    Luigi
