uninstalled 8 reinstalled 7.1, works again. hehe
WOW!! SO COOL!!
Do you have test one GTX590 ? How many Node blur 100% with 1080p Prores422HQ ?
thanks
big thumbs up to luigi ( can render now on 3 gfx480!!!!
cooling the cards is still a wild one over here - but it works
can use the cudas in paralell for rendering in octane renderer ( high speed )
please make gtx590 driver available - 3 cards and we go to the moon:)
best ones
tony
hi ,
in this moment guyssss not have a time for HACK, i have much work for television.
The problem of gtx 590 is dual gpu in 1 pcb , 1 is recognize vga compatiblen and second is recognize 3D controller and driver no upload for second GPu....
but i work for this. But step by step i found solution... only time....
LSPCI:
04:00.0 3D controller: nVidia Corporation Unknown device 1088 (rev a1)
04:00.1 Audio device: nVidia Corporation GF110 High Definition Audio Controller (rev a1)
05:00.0 VGA compatible controller: nVidia Corporation Unknown device 1088 (rev a1)
05:00.1 Audio device: nVidia Corporation GF110 High Definition Audio Controller (rev a1)
Ermac have added to chameleon id of gpu :)
chameleon Trunk:
{ 0x10DE1054, "GeForce GT 410M" },
{ 0x10DE1056, "NVS 4200M" },
{ 0x10DE1057, "NVS 4200M" },
{ 0x10DE107F, "NVIDIA GF119-ES" },
{ 0x10DE1080, "GeForce GTX 580" },
{ 0x10DE1081, "GeForce GTX 570" },
{ 0x10DE1082, "GeForce GTX 560 Ti" },
{ 0x10DE1083, "D13U" },
{ 0x10DE1086, "GeForce GTX 570" },
{ 0x10DE1088, "GeForce GTX 590" },
// 1090 - 109F
thanks
Luigi
I was wondering if it perhaps might be a better idea with using EFI strings?
It should be possible for the installer to detect the cards through ioreg and generate a EFI string on the fly. I could never get the DSDT file to work, but with the right EFI string everything (atleast the graphic cards) works perfect.
I might be able to whip up a quick python script for doing that...
I am very grateful for the professional work for "Mac-Asus-Supercomputer team" Very big thanks to the excellent work of Luigi! My Davinci system works so brilliantly....
Intel Core I7-970 on +4,0GhHz.
3-Gigabyte GTX-470
12Gb Ram
Redrocket-card
Highpoint Raid
some new.......
my frined Jose Lomena test NETSTOR NA250N in Hackintosh whit 3 gtx 480 this is result:
Netstor NA250A
- PCI expander with 4 pcie x8 + 2 pcie x4 slots
- 40gbps host pcie x8 v2. 2 meters cable
- up to 4x gtx480
- setup with:
2x gtx480
1x. Decklink multibridge
1x sonnet e4p
2x free slots (for redrocket)
My hackintosh...gigabyte i7 980x, 24gb with:
1x ati 5770 for monitors
1x host Na250a
1x gtx480
Candle Test resuls with resolve8 and 3 gpu gtx480
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 24 fps
V4 12 nodes :24 fps
V4-x2 24 nodes: 21fps
V5 NR 4 : 24 fps
V6 NR 3 : 24 fps
V7 NR 2: 24 fps
V8 NR 1 : 12 fps
I remember you Kernel osx support max 4 GPU.
Next test Jose use NETSTOR whit MAC PRO and 4 gtx 480... waiting result.. this is possible solution for real MAC.
If this work i post here solution.
thanks
Luigi
Sounds great!
I also decided to build a similar system, though it is almost impossible to find new GTX 470 cards; most I found are second hand and coming from intense gamers, probably from smoke filled rooms... :(
The issue is that one needs 3 identical cards for a working rig and if one fails, things will go pear shape big time, especially if in the middle of project, or client session.
@ Luigi,
I know you are very busy, but I am not clear if the new Machete v2 supports the new, readily available, GTX 570 cards.
Thank you,
Valeriu
