Thread: DAVINCI RESOLVE and ***HACKINTOSH***
Page 5 of 60 FirstFirst 1234567891555 ... LastLast
Results 41 to 50 of 595
  1. #41
    Quote Originally Posted by David Kellermann View Post
    My configuration:
    1 - empty
    2 - empty (HMDI output)
    3 - GTX480
    4 - Blackmagic Decklink 3D+
    5 - GTX480
    6 - Areca 1880i
    7 - GTX480
    Quick question, does the P6T7 allow for double spaced PCIe cards not to overlap the other PCIe slots or are you using some other means to keep the cards using only one PCIe slot. Does watercooling allow you to lose the large fans and hence allow you to fit your Areca and BM decklink in between? Looking at the board I always imagined those types of graphics cards would always create this issue.
    Paul
    E N T S W O O D Ltd
    Camera Kit Rental - Epic, Alexa, Master Primes, Ultra Primes, Aluras, Cooke Panchro SII/SIII, Grip, Monitoring etc
    Paul Clements - DIT Red Camera (Digital Imaging Technician
    London - Manchester
    +44 (0)7786 444333
    www.entswood.co.uk
    paulclementscx@gmail.com
    Senior Member David Kellermann's Avatar
    May 2009
    Freiburg, Germany & Prague, Czech Republic
    Quote Originally Posted by PaulClements View Post
    Paul
    Hi Paul,
    the fans would normally overlap a second PCIe slot. I'm using Aquacomputer coolers to fit the cards into a single slot. The coolers are awesome and not to expansiv, but their connector (Twinconnect) is terrible. I flooded my PC three times before it worked (fortunaltey I started a test run without plugging the PC in, powering the pump from an old power supply). Water was leaking out between the bridge and the cooler. It's possible to fix it with silicon sealant.
    The Areca and the Blackmagic cards fit in between (I had to remove for both cards a srew on the watercoolers which were blocking their fans).
    If I would set up a new system, I would rather take a different company then Aquacomputer, where it's possible to screw the plugs directly into the cooler. Just be sure that the connectors are high enough so they don't block other cards (the Areca is low profile anyway).
    Maybe these:
    http://www.aquatuning.de/product_inf...---1-Slot.html
    A good shop wich I would recommend:
    http://www.aquatuning.de/index.php/language/en
    If you have any questions, write me a pm.
    David
    PS: I'm not working for Aquatuning, I just had good experience with them
    a better TRUTH . commercials & workflow management & aerial cinematography
    Germany | Czech Republic
    http://www.a-better-truth.com
    Have a look at my last short-film and vote for it, if you like it!
    Partner @ Short of the Week
    Senior Member luigivaltulini's Avatar
    Oct 2009
    Switzerland- LUGANO
    yess i Quote David , is terrible ...........
    Senior Member Justen Nguyen's Avatar
    Apr 2009
    Orange County, CA
    luigi, thank you for this!
    Oct 2009
    Switzerland- LUGANO
    Quote Originally Posted by Justin Nguyen View Post
    thanks guys.
    and thanks you Justin :)
    Oct 2009
    Switzerland- LUGANO
    CIAO GUYS,
    I worked hard for this problem, the system had problems installing Avid 5.0.3 and some soft of Foundry. SystemID did not recognize the machine (see screenshot).
    Fixed bug with digital audio + USB+ increases system stability and performance + integrate 2 lan in table , now the ACPI tables are APPLE'S LIKE
    Find the link to download in first post and find the new installer CUDA GENERATION .(this link have a utility for check systemID)
    I recommend you backup your system!! so it does not work you can restart.
    and download bios Pics (link first page for max stability settings)
    I look forward to hearing from you
    LUIGI
    Oct 2009
    Switzerland- LUGANO
    Thanks to
    ROHIT GUPTA and JOSE.
    For best performance setting in DAVINCI DEBUG MENU
    LsManager.3.NumGPUs = 2 ***GPU you HAVE in HACK**
    LsManager.3.GPUMapping = 0 1 *** 0 1 2 .. GPU ***
    LsManager.3.GPUMappingEnable = 1 *** 1 Default ***
    SEe pics in my case 4 gtx
    Junior Member
    Jan 2011
    INDIA
    Hi luigivaltulini..thanks for your tutorials .
    i have a Intel Core2 Duo Cpu E8400,Intel media series motherboard,4gb ddr3 ram
    with quadro fx 1800..system..can i convert as a hackintosh and run Davinci for my learning purpose? please help me
    Oct 2009
    Switzerland- LUGANO
    Quote Originally Posted by ajaykumar View Post
    you can try. But it is difficult even for the ACPI table. you have
    Snow leopard original and a Mac running?
    1. which motherboard? gigabyte, asus, intel? model?
    Junior Member
    Jan 2011
    INDIA
    sorry ..i dont have Mac system ,
    here is my system details:-
    motherboard:Intel media series DP35
    Processor x86 Family 6 Model 23 Stepping 6 GenuineIntel ~2999 Mhz[Intel Core2 Duo Cpu E8400]
    Quadro fx 1800
