Click here to go to the first RED TEAM post in this thread.   Thread: BLACK LEVEL
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1 BLACK LEVEL
    In Resolve you can monitor using video levels or full range data. In my projector, that means a huge difference in black levels. Since I'm targeting to a film print using a 3d lut, I'd like to use the the full range to get the most of the projector. My problem is that when I get out of Resolve and playback the rendered files in FCP, the black level is in video range and my images look flat. I think the answer is to grade in Resolve using video level to get compatibility with FCP, but I wonder if there's any way to display the same full range levels in both programs. I'm monitoring with the Decklink Extreme 3D.
    Any ideas?
    Thanks, Daniel
    Kiné-Imágenes
    Creación de Imágenes Digitales
    Santiago de Chile
    Aug 2010
    If you render to a RGB codec, you should get full levels in FCP I think. Try using Uncompressed RGB.
    I thought that RGB in FCP was 8 bit only?
    Albert
  4.   Click here to go to the next RED TEAM post in this thread.
  #4
    FCP is 8bit only rendering in RGB, so I'd if you're using FCP, I'd go with a YCbCr codec and video levels as that's really how it was designed to work.
    For projection - does the projector have a setting for the levels of data that it expects?
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    Aug 2010
    Quote Originally Posted by Albert Armes View Post
    Albert
    You can use the BMD 10 bit RGB codec.
    My path is decklink sdi - hdlink sdi to hdmi - hdmi into jvc rs-20.
    I' m making a new calibration based on video levels and adjusted the contrast and bightness to have a good black and see the pluge.
    The projector lets me select color space (rgb or ycbcr) but it just works in rgb despite what I configure in video out. I think it's hdlink that outputs only rgb 8 bit (even if I feed it with dual link sdi, the projector always tell me it's receiving 8 bit.)
    I prefer ycbcr codecs if I'll pass in FCP, I tried aja 10 bit rgb and couldn't make a dissolve without gamma jumps and banding.
    Thanks!
    Kiné-Imágenes
    Santiago de Chile
    Senior Member Luis Otero's Avatar
    Orlando, FL
    This is a subject that should be discussed and explained more on this thread since there is no much information written or shared either at the Resolve Manual or throughout the forum.
    Can someone care to share more information and experiences on this topic?
    Thanks,
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    I was scammed, and I love it...!
    Digital Emulsion
    Orlando, FL
    IMDB: www.imdb.com/name/nm3889059/
    Senior Member jake blackstone's Avatar
    Nov 2007
    A lot depends on your deliverables. If you're finishing for video delivery, then you're better off monitoring SMPTE levels. This way everything will look the same from grading all the way to delivery. BTW, using dual SDI means, that you're monitoring 444 signal vs 422 and not 10 bit, vs 8 bit. You don't really need to do that for monitoring. Being 10 bit is much important, than using 444 sampling. Unfortunately, all this doesn't really help with gamma issues, but at least this should get you a bit closer. I also would pay close attention to the proper calibration of your monitors.
    Personally, whenever I have to use QT, I use AJA or BM 10 bit RGB codec, as they both allow for full and legal levels...
    Short answer:
    When using Resolve your monitoringsettings must match your output format.
    YUV Outputs (QT YUV, ProRes etc..): Normally scaled legal video
    RGB Outputs (QT RGB, DPX, TIFF, OpenEXR etc...): Unscaled full data range
    I really think this should be better explained in the manual as doing it wrong will give you wrong levels on output.
    There is also an issue if you need to deliver both YUV and RGB files (f.ex RGB files to VFX if they ask for it). I ended up doing it inn Full range but grading everything within legal levels and giving the FCP people a QT RGB while the VFX guys got DPX.
    Freelance Colorist / Online operator (2D & s3D)
    Apple Distinguished Professional Video / Broadcast
    Apple Certified Trainer
    www.icolor.no
    Sure if you work for video, you have to monitor in video levels, my issue is I'm grading for film out (so I should go full scale/rgb) but when I review the results in FCP the blacks are higher and washed using the same LUT in a external HDlink.
    Right now I'm using Resolve in video levels to match both images, but, is there a way to make FCP + Decklink to monitor full scale?
    Kiné-Imágenes
    Santiago de Chile
Tags for this Thread
View Tag Cloud
