Click here to go to the first RED TEAM post in this thread.   Thread: TC syncing
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Senior Member Rainer Fritz's Avatar
    Vienna
    thx noah again for your help...
    Senior Member Noah Kadner's Avatar
    Quote Originally Posted by gunleik View Post
    Just a fun thought
    If you use something like episode, (which exports qt-formats), would it be possible to batch process?
    Gunleik
    Episode or Compressor- but you'd be batch processing the QT proxies created by the camera. Only Red Alert can directly open the .R3D files.
    My question for Graeme would be- if I open say a 2K QT proxy in Episode and export a 4K ProRes- am I actually getting access to the 4K .R3D original for the conversion or just upconverting the 2K proxy to 4K?
    -Noah
    Norway
    Ah... So there's still no RAW QT component...
    Got it.
    Cheers!
    Gunleik
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
  4.   This is the last RED TEAM post in this thread.   #14
    Noah: you will be upconverting. A 2K input source is a 2K input source (for applications that can't access the R3D directly, unlike RED ALERT! / REDCINE / Scratch)
    ROBCODE Santa Claus @ RED
    "You get the chicken by waiting for the egg to hatch, not by smashing it with a hammer" - Jarred
    Junior Member
    Nov 2007
    I'm new to this forum. Hello everyone.
    I'm doing production sound on a Red shoot right now, and the timecode I see on the monitor always seems to be a bit off, maybe about a 1/2 second. The only way to tell has been to check it by eye. The Denekey slate and the TC on the recorder are solid, but the TC display on the Red monitor is always 1/2 second off and it does not seem to drift from that the whole shoot. I have a Clockit timecode generator (jammed from my recorder) connected to the camera at all times via the 5 pin Lemo cable. The Denekey slate was jammed from the Clockit box, so the slate and the camera should theoretically be running perfectly in sync.
    Note: The Red does not jam the timecode being input until you are recording. When it jams, the little chain link icon appears at the top center of the monitor after the first take is stopped.
