Originally Posted by
Bruce Allen
It's closest relative would be the ultra-expensive high-end digital cinema cameras - eg Genesis, D20, Dalsa, Viper. It is competitive (and possibly / probably even beats some of them) in terms of sharpness, latitude, noise etc. It has the depth of field of a 35mm film camera. Because it records in a raw format, the image can be tweaked, re-white-balanced, etc in post easily. Color saturation etc can be adjusted very easily afterwards without too much posterization. If you have time, try to do some tests and work with the people on set to get them to show you the approximate look they're going for. The Red's image is flexible so you need to get an idea of what ballpark they're shooting for with the grade. What you see on some monitors on set may very well be way off from final saturation, warmth, color, contrast, etc (unlike, say lower-end HD cameras, where the look is tweaked closer to final while shooting because they have less latitude for extreme adjustments in post).
The sensitivity of its sensor is ASA320, although it can be pushed significantly and still look good.
Officially it's rated at 11.5 stops of latitude although depending on how much grain in the shadows the DP is prepared to put up with it might be more like 9.5 stops.
Probably the best thing for you to practice with would be a digital SLR still camera. The highlight response should be very similar to that. In my humble opinion, the Red is not as sharp and does not have quite the latitude of the current state of the art DSLRs, but if you do makeup work that looks good if you shoot it with a digital SLR camera (doesn't need to be an expensive one, an entry-level one should be fine), that should put you in the right ballpark. If you know Photoshop or a digital photo program such as Lightroom, Aperture, etc, that's great. Try shooting in a "RAW" and tweaking the colors afterwards to get an idea of how much can be done in post - and how much it can affect your makeup!
Of course I don't own a Red. I have only played with one or two, seen test footage, seen it projected and graded on a 2K Barco at RPM Post, etc. But hopefully this should help.
