Do people still use waveforms in hardware form? When working with 4K footage, how would i get a 4K signal into a waveform to monitor my signal accurately?
TIA, Simon
TIA, Simon
It's not a video camera. Not sure what a waveform is going to tell you. Best you could hope for is to run the video tap out but why? You're recording 4k RAW files. A waveform has no relevance.
hardware scopes are still relevant, all of our editors and colorists rely on them every day. Are you actually editing in 4K though?
I'm not editing in 4K yet, but yes, scopes for colour are very relavant!! How do they monitor the colours on a Spirit 2K or 4K. I remember they have to line up the film on a waveform to start with......?
If you master for TV you can´t live without them.
To work with 4K? the IRE values still the same, or.... not?
If you're mastering for TV, 4K as a finishing format is irrelevant and will be for quite some time. You would be monitoring HD, for which there are many scope solutions. For many colorists, traditional style scopes are simply a nice, simple to use, and unambiguous reference for things like white and black balance and overall levels. Using HD scopes is just as useful even if you're using a downconversion for this purpose.
External / hardware scopes are still good for checking your output falls within your desired parameters, among other things. When working with media that holds more color or spatial resolution than your monitoring or output format, you really do need software scopes internal to your applications software so that you can better quantify what is going on. But yeah, a hardware scope is of limited utility when you're shooting 16bit REDCODE RAW on Epic and you have already modified the source by down-scaling to 1/5th of acquisition resolution and compressed your color space into 10bit log before sending out to the scope. Mostly their application at this point is checking your HD/SD deliverable output.
Thanks Jeff. So i look at my software scopes for 4K and my waveform for HD-SDI. What happens if Jim get's his way and we have 4K TV???!
What happens if you get hit by a bus?
It hasn't happened yet. When it does, you and everyone else will deal with it, just like we have every other format that's ever shown up. Manufacturers will come up with both software and hardware based solutions. The world will go on.
But...but.. what about 8k?:-)
