Click here to go to the first RED TEAM post in this thread.   Thread: Quicktime output issues
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 Quicktime output issues
    Senior Member Paolo Tinari's Avatar
    Jan 2007
    Outputting quicktime i see only the first frame along the whole clip. Tried h264 and cineform in many format/quality (i have prospect and qt updated).
    The qt go on premiere timeline but there too i have only the first frame.
    I'm i doing something wrong?
    The outputted cineon folder opens and run 2k in AE amazingly
    Jan 2007
    I see i'm not the only one getting 1st frame only with QT output.
    I have athlon 64 x2 dual 3gb ram and nvidia geforce 7800 gtx.
    Anyone?
    REDuser Sponsor Chris Parker's Avatar
    Jan 2007
    I am having the same problem. Can someone post the solution to this in this thread please?
    I dont get how this is a gfx card issue as I'm seeing the frames as its apparently exporting to a QT sq.. :-/ possible QT problem? if img seq are working etc...
    s
    MatteBlackFilms
    Space Digital Visual Effects & Post Production
    Jan 2007
    Now i cant output dpx or cineons anymore, same settings as before...
    I think i'll wait for 1.2...
    Yesterday i've exported a dpx 2k sequence, imported and graded in ae and ouputted in cineform avi and imported in a premiere/prospect 2k 24p timeline. All smooth as silk, stunning images.
    hmm... so things are getting worse? wierd...
    s
    MatteBlackFilms
  7.   This is the last RED TEAM post in this thread.   #7
    Make sure when you're outputting image sequences you include the frame number in the filename so you don't get one big file.
    For QuickTimes (especially on OS X) you might want to try re-installing REDCINE and repairing disk permissions. Also check your installed QuickTime version.
    ROBCODE Santa Claus @ RED
    "You get the chicken by waiting for the egg to hatch, not by smashing it with a hammer" - Jarred
    Senior Member Casey Green's Avatar
    Feb 2007
    I, along with several others, am having this same "1st frame problem" as I mentioned in 2 other threads. Exporting Quicktime not Image Sequences.
    Rob, has RED been able to reproduce this? If so, can you step us through the repair process? Thanks for any help you can offer.
    http://www.reduser.net/forum/showthr...791#post108791
    http://www.reduser.net/forum/showthr...433#post108433
    MBPro 2.16GHz ICD
    1GB 667MHz RAM
    FCP 6.0.2
    QT 7.3.0
    OSX 10.4.11
    Quote Originally Posted by Casey Green View Post
    MBPro 2.16GHz ICD
    1GB 667MHz RAM
    FCP 6.0.2
    QT 7.3.0
    OSX 10.4.11
    Casey,
    Please post your logfiles into the new Sticky - Logfiles.
    Lucas
    ASSIMILATE, Inc.
    LA, CA, USA
    Feb 2007
    Will do. Thanks for the heads up, Lucas.
