Thread: EPIC accessories from ActionProducts
Page 7 of 35 FirstFirst ... 3456789101117 ... LastLast
Results 61 to 70 of 347
  1. #61
    Jul 2007
    Marseille/France
    If that plate attaches directly to the RED one body as it seems to do, then yes our riser plate should work just fine.
    This Sim base plate uses the first 3/8 and the third 1/4 holes from the lens side on the Red one.Won't the EPIC be too far behind?
    Nice new stuff!
    http://planb-red.com
    Red Epic camera rental
    Location caméra Red Epic
    Marseille
    REDuser Sponsor Brian D. Goff's Avatar
    Switzerland
    Quote Originally Posted by AnthonyFlores View Post
    +1 Agreed. This is amazing. Also curious to know price and availability ....
    I need about a week to be able to say more to pricing and availability - so stay tuned:)
    Brian D.Goff
    Owner/Chief Designer ActionProducts
    DoP
    www.actionproducts.ch
    info@actionproducts.ch
    ShowReel (DP/ActionCam)
    www.brian.goff.ch
    EPIC-X with Electras & co, Leica R 15mm to 560mm Primes and Zooms
    Senior Member Jason Wingrove's Avatar
    Sep 2007
    Sydney Australia
    Thanks Brian. look forward to hearing more.
    jas
    Jason Wingrove
    Director, Cinematographer
    EPIC X22
    Web: wingrove.tv
    Twitter: wingrove
    Cohost: The RC Podcast
    Senior Member Steffen Vala's Avatar
    Mar 2009
    London, UK
    I just wanted to chime in to say that having an arsenal of ActionProducts goods...we are super happy with them. And recently stepping up to the ActionCam RebelPro has been a great addition to our kit. Brian has been extra helpful and always available when we have questions about best practices and configurations etc. Thanks Brian.
    I look forward to more great stuff from AP! These designs look excellent.
    Best,
    Steffen
    Freelance DIT and 2D/3D Character Animator
    London, UK
    OnlyRental.dk Copenhagen, Denmark
    Over 100 days on EPIC shoots - 2011 REDucation UK - Advanced Group
    Senior Member KETCH ROSSi's Avatar
    Jan 2007
    ITALY
    Quote Originally Posted by Brian D. Goff View Post
    The Riser and Audio-Riser are now shipping. The "Top mount pro" and "Power distributor" are in the works. Both accessories expand the EPIC brain to a new level, by adding the missing links: Power sockets and better accessible BNC's - enjoy!
    Bottom mount featuring:
    -2 x 3.5mm jack plug to Pro XLR at rear
    -acts as spacer to use industry standard base plates
    -accepts upcoming 15mm light weight rod assembly
    -Tape measure hook on left and right
    15mm light weight rod assembly featuring:
    -Works with Audio-Riser
    -Protects 3.5mm Audio Plugs and hides them neatly
    -15mm DSMC centered standard
    Top mount Pro features:
    -power sockets the EPIC lacks (requires power source like a V-mount battery).
    -Provides BNC connectors for HD-SDI (the current EPIC BNC is located in a difficult to get spot and this is an very important BNC)
    -SS/GPI; TC; GENLOCK BNC's (rather than the small 4pin connector the EPIC uses).
    Power distributor features:
    -rugged Battery mount for the EPIC (V- Mount, Anton Baur, ect.); can be mounted so battery looks down for more compact configuration
    -use of different power sources over RED 5pin Lemo and industry standard 4pin XLR.
    -also it brings the Audio plug to a user friendly location
    -provides stabilized 12V and 24V power sockets.
    All milled with swiss precision and 7075 grade aluminum
    Okay, having had a little time reviewing this on my MBP instead of my iPhone... ;), two things are to be immediately considered, when using the camera in a standard 2D configuration you will need to clear the bottom at Dovetail high,
    so not o be obstructed when sliding the camera forward, when operating in 3D, if using ET's Atom, were the cameras are mounted via a special Top plate then the Battery needs to be no higher then the top plate or it will obstruct its movement on the top mounted dovetail, so need to choose carefully which one does you best, or if like us that we shoot both 2D and 3D then you ned both ways, at list till RED releases their Battery Modules with Hotswap capability, which would be also a great add on if this could have such capacity, but it is understood this will add size and weight,
    Brian, are you testing this on an Actual Epic M? If not It will be a pleasure to test them on one of ours here in Rome, and then returned to you, or most then likely keep them as we would be surely buying them both types, as it is a much better solution then out current ones were a battery plate is attached via Rods and or Clip with dangling cables.
    KETCH ROSSi | EPIC-M DRAGON M8
    Producer | Director | DoP |
    *CinePhotographer
    __________________________________________________
    *Registered Trademark of RED DIGITAL CINEMA
    Switzerland
    Hi Ketch
    Thanks for the input - I'm fine tuning, so I'll try to pay atention to these things. I'm testing on Octamas's EPIC M in Zürich, but I'm sure we'll get you some equipment to test-drive:)
    Cheers
    Brian
    Quote Originally Posted by KETCH ROSSi View Post
    Brian D.Goff
    DoP
    www.brian.goff.ch
    Jan 2007
    Great to hear about the USB charging.[/Off topic]
    Writer - Director
    Crowing Lakes.com
    Senior Member Raphael Varandas's Avatar
    Jan 2008
    Sao Paulo - Brazil
    Thanks so much Brian...very nice product.
    Very nice work.
    I will stay tunned.
    Hoping to know more about specs and prices
    cheers
    DCINE
    Cinematografia Digital
    www.dcine.tv
    www.vimeo.com/dcine
    www.facebook.com/Dcine.Digital.Cinema
    2x RED 1 MX
    2x EPIC M
    1x EPIC X
    2x SCARLET
    5i set coming
    Leica set coming
    atendimento@dcine.tv
    raphael@dcine.tv
    SAO PAULO / BRASIL / 55.11.55498419
    Switzerland
    Hi Jean
    Probably the EPIC will be further back - but don't think that is a problem, just might not look to cool:) - maybe drill some holes into the SIM plate?
    Brian
    Quote Originally Posted by Jean Wallez View Post
    Nice new stuff!
    Brian D.Goff
    DoP
    www.brian.goff.ch
    Jul 2007
    Marseille/France
    Yes,drilling a new hole seems to be the solution.
    Thank's Brian.
    For European customers,are there import taxes now?
    Marseille
