Click here to go to the first RED TEAM post in this thread.   Thread: MetaCheater Utility
Page 4 of 11 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 108
  1. #31
    Senior Member Arnaud Paris's Avatar
    Jan 2007
    Paris, FRANCE
    Yes, a paypal donation system would make sense. Can you look into this.
    Arno
  2. #32 New Version
    Thanks for the talk of donations. I don't really know how I'd go about setting anything up though, but I'll look into it.
    In the mean time here is a new version:
    http://www.mediafire.com/?d7wzjjemz7x
    Version 1.0
    It has the ability to add Prefixes and Suffixes.
    Also it allows for the use of each clip's filename as its Tape name. Actual it is the Reel, Clip and Date parts of the R3d filename, limited to the first 16 characters (in order to work with Avid's EDL template for Red)
    cheers
    -Jabez
    Senior Member sbaechler's Avatar
    May 2007
    Zürich
    Hi
    Your tool is great.
    Is it possible to use Quicktime Pro (or Cleaner XL which uses QT) to convert the Red Proxies to an Avid QT like Avid DV so you don't need the actual Avid software to do this? Are the metadatas stored in the proxies as well?
    Or is there a way to make Avid Fast-Importable files without having to buy an avid suite?
    Regards
    Simon
    Simon Bächler // Cinematographer // Zürich, Switzerland // www.stellanera.com // www.workflows.info
    Aug 2007
    Boston
    As long as the Avid QuickTime codecs are loaded on the system, available free form Avid.com, QuickTime Pro can make the proxies as needed. No Avid needed on the system.
    As long as you can read the RED Proxies (so have the QT codec) and can write Avid QT files (have the Avid codecs) then you should be able to do the conversion in any QT-capable product.
    I've done it with Compressor on the Mac. It took about 2x realtime for a 2-minute clip from 1k Proxy to DV50 Avid QT (so around 4 minutes) on our 8-core MacPro. And then the fast import to Avid still takes around 30 seconds.
    It would be better to import directly to Avid from the QT proxies, I think, as that way you're getting Avid-ready mediafiles and a nice Bin.
    Dylan Reeve
    Edit Geek
    May 2007
    Zürich
    Yes. The best would be if there was an mxf tool that would make the media files directly. The bin file would be a plus but not necessary.
    On the p2 system you just copy the mxfs in the AvidMediaFiles folder and the import into the project is very fast.
    Is there a software that makes MXFs out of Quicktime? It doesn't have to be an Avid software since MXF is an open format.
    What would be the best setting for Avid QT? For me this is always a long trial and error procedure...
    For PAL DV I would set it to DV 4:2:0, lower field first, RGB color space. Is this correct?
    -Simon
    Aug 2007
    Boston
    You don't want to go the extra step of an already created DNxHD encoded QuickTime to MXF since the lengthy part of the process is the essence encoding, not the metadata wrapping.
    Michael
    Feb 2007
    Also just from practical experiance, if you use the quicktime methodology, it prevents a lot of the problems of transferring avid media to multiple different stations that arn't on some kind of shared storage. It continuosly suprises me some of the ass backwards editorial workflows that exist, ie but I can just have my editor log and capture to both avid meridien's and save the cost of getting a lanshare.
    May 2007
    Zürich
    Quote Originally Posted by MichaelP View Post
    Michael
    Yes, the MXF would be in an native Avid format. Even Fast-Importing Quicktimes takes a while if there are a lot of clips. Especially if audio is involved.
    I noticed that Avid is not a multi-core application. If I encode to an Avid codec in Quicktime pro, are all available cores used?
    -Simon
    Aug 2007
    Boston
    I have been focusing more on RedCine of late which does have multicore support.
    Michael
