Currently if I select the naming system [EVENT#Z/#F.MOV] I get each clip with the same name as the R3d file in it's own folder in my destination folder.
If I select the naming convention[#F.MOV] then I get all the clips in my destination directory but only the first clip renders correctly. Each subsequent clip shows the last frame of the first clip but shows the correct TC and name on the burnin.
This is in build60 due to weird colours and 24fps overriding 25fps in the burnin window in build66.
As a future request I'd like to be able to render clips so they render into one directory per card number ie. all A001_ clips into an A001 folder etc.
Regards
B
