Click here to go to the first RED TEAM post in this thread.   Thread: EPIC > ProRes via AJA KiPro Mini
Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 75
  1. #1 EPIC > ProRes via AJA KiPro Mini
    New firmware for your AJA KiPro Mini.
    One cable - SDI (or wireless w/ BOXX).
    Auto start/stop.
    Filenames & Timecode recorded same as R3D.
    http://www.aja.com/support/ki-pro/ki-pro-mini.php
    Thank you AJA - it's about time :)
    Jul 2007
    Can you generate proper slowmo prores footage eg.300fps with this box ?
    Senior Member Tom.Wong's Avatar
    Jul 2009
    New York/New Jersey
    Quote Originally Posted by RivaiC View Post
    you'll have to record to internal ssd first and than play out over sdi to record. unfortunately epic has no internal playback at the moment, you could always do it out of a rocket.
    Jul 2007
    Ah I see, thx for clarification tom. I was thinking live record during take, one straight to ssd and the other one via hd-sdi. I guess the only way to record proper slowmo is after the recording.
    Regards
    Rivai
    Digital FX Greg M's Avatar
    embedded audio via SDI also?
    digitalfx.tv
    The RGBlog- Ramblings about Cameras, VFX, etc.
    Twitter
    Red One #83
    Epic-M #98 and #240
    Epic-X #83 and #116
  6.   Click here to go to the next RED TEAM post in this thread.
  #6
    Red Team Deanan's Avatar
    Jan 2007
    Quote Originally Posted by Greg M View Post
    that's coming on the epic side.
    Deanan any wild estimates regards playback on the Epic? Without it, the Ki Pro mini is only half a solution (glass half full, not empty) as it's only really good for shots taken at the base frame rate.
    Mark Pugh LA,NYC, and AUS.
    www.markpughfilms.com
    Several EPICs...
  8.   This is the last RED TEAM post in this thread.   #8
    Jan 2007
    Quote Originally Posted by Mark Pugh View Post
    I wouldn't agree with that assessment. KiPro plus epic is very powerful for many situations. Playback is a side effect.
    Of course, playback is #1 on the priority list currently.
    Senior Member Sanjin Jukic's Avatar
    Vienna, Austria
    Finally happened, thanks AJA, also to RED team...!!!
    The next step should be HDMI out to Ninja or similar BM lightweight SSD HDMI recorders...
    "There is no point in having sharp images when you've fuzzy ideas."
    Jean-Luc Godard.
    Dynamic range is, after all, the measurement between well saturation (photosite blowout) and noise floor.
    Thom Hogan
    500px >>>
    Twitter >>>
    Facebook >>>
    Vimeo >>>
    I'd say that with this kind of third party solution maybe a "wireless module" is more important than a "proxy module". The key Pro records everything just about any NLE can handle and with TC support it's a great solution.
    A "wireless module", somthing that distributes a low rez image stream from the camera around the set (or to a director/producer/VFX house/ etc half a world away who can't be on set). That would be pretty slick.
    Maybe much more handy than a proxy module.
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
