Thread: Third Party Red battery Repair?
Results 1 to 6 of 6
  1. #1 Third Party Red battery Repair?
    Senior Member nacamera's Avatar
    Milwaukee, WI
    I have a FUNCTIONING Red battery that was just dropped on a rental. It now does everything it should do, except when you press the indicator button on the side of the battery it doesn't light up to show you the charge at that point. The might DO come on when the battery is on the Red Charger, and the battery is functional other than this one issue. I'm sure it's just a loose wire or something, but I don't want to crack the case open myself, and Red is strictly "Hands Off" when it comes to supporting/repairing their own batteries. Does anyone have any third party battery repair recommendations? I'm in the Midwest, but I'll ship it anywhere.
    Thanks,
    Bob Donnelly
    North American Camera, LLC
    Milwaukee, WI
    www.nacamera.com
    414.765.1111
    Senior Member Kemalettin Sert's Avatar
    May 2009
    Turkey
    same problem on here..dropped battery and lack of indicator lights.
    I repair Video camera batteries, have done over 800 Li-Ion packs, the majority being the Anton Bauer Dionics, the rest being IDX, Sony, Frezzi, Varizoom and an assortment of Chinese knockoff.
    Been looking to get hold of a Red brick to evaluate and do a test repair on it.
    If anyone has a bad one laying around and wants to send it to me I will do a couple for free to get some feedback on the results.
    You can contact me at 954-557-9765, Email siebold35@hotmail.com, website: www.ritterbattery.com
    Hello all
    I wish to thank everyone that responded to the repair offer, I received an overwhelming response so
    the free repair is no longer available.
    I will be posting the results in the next few weeks as soon as the promised shipments arrive.
    Regards John Ritter
    Update:
    So far I have received 3 Red battery packs, 2 - 9.4AH & 1 - 10.4AH
    Interestingly; all 3 packs use the same control board but 3 different manufacturer's cells: Sanyo, LG Chem, Samsung and 3 cell ratings: 2200, 2250, 2600
    Also all 3 had either a pinched wire (manufacturer process) or a broken wire to the control board.
    All of them were a simple repair, but resetting the on board EPROM requires that the balance leads be disconnected from the control board.
    The longest part is, the time required to test the packs as discharge time varies from 2 hours to 5 hours and recharge is about 3-4 hours.
    So I can say that the RED battery packs are repairable and can be Re-Celled, I will post the users experience after I send them back, still want to do a couple of rounds of cycle testing.
    All 3 packs tested out at 70% or better of original capacity (I only tested to 5 amp load or 70 watts nominal)
    Regards John Ritter
    New Update:
    Well so far the count is, 8 Red Brick batteries that I have seen. (9.4 & 10.4AH)
    All were completely repairable, minor broken wiring issue's, I have returned the last 3 today and I await
    So Yes the RED Battery is fully repairable and can be Re-Celled.
    It seems to be a common problem after the first batch to cross my workbench, this kind of repair and test service will run about $50.00
    including the return shipping (CONUSA only international would be additional).
    If a full cell bank replacement is required (RE-Cell) this would run $240.00 per pack (Re-Cell would be to 10.4AH).
    Regards John Ritter
Tags for this Thread
View Tag Cloud
