Click here to go to the first RED TEAM post in this thread.   Thread: HELP!!!!! RED ROCKET ISSUES!!!
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1 HELP!!!!! RED ROCKET ISSUES!!!
    REDCINE-X is not recognizing my RR. It has the latest firmware (1.1.15.5) and driver (1.4.15.0). I tried to reinstall the firmware but I get this message:
    SV_ERROR_DRIVER_MEMORYINIT, On card memory init failed.
    ERROR:
    What could it be?!?!
    Senior Member Justin Marx's Avatar
    Jul 2011
    Hollywood, FL
    Is this a new install?
    EPIC-M 1261 - officially named "Take 2"
  3.   This is the last RED TEAM post in this thread.   #3
    Contact RED support if you have not done so already.
    BC
    No, it is not a new install. Actually I've been using it weeks. This issue began yesterday. I'm in the middle of a movie and this really sucks!!! I did contacted the RED support. Not answers yet.
    Senior Member Fred Beahm's Avatar
    Sep 2011
    Seattle, WA
    Are you on RCX-Pro, or a earlier build?
    REDCINE 501, but I have try it with 487 and 356. The 356 recognizes it, but says it needs firmware 1.3.5 wich I can't find anymore!
    Try a safe restart:
    -take the rocket out of the computer, switch the dip switch # 8 at the bottom of the card to I (other direction than 1-7)
    -put it back in, restart and reinstall driver and firmware
    -take the card back out and put dip switch #8 back to 0
    You should be good to go...
    ______________________
    Florian Stadler, D.P., L.A.
    www.florianstadler.com
    www.buntefarben.com
    I'll give it a try and let you know. Thanks!
    Oh, i forgot to mention that in this show because the locations and all the moves I've been using it with a magma ExpressBox. It was working great until now. I have two Macbooks. A 15" C2D 2.4 and a brand new 17" thunderbold i7 quad. Until Monday I won't be able to put it back to my tower.
    Florian, I put the dip switch #8 to the oposite direction than 1-7 as you said, but when I try to install the firmware, again it gives me the "SV_ERROR_DRIVER_MEMORYINIT, On card memory init failed." error. So I guess it did not work. :(
