Click here to go to the first RED TEAM post in this thread.   Thread: EPIC Native ISO
Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 60
  1. #1 EPIC Native ISO
    Junior Member John Smyrnios's Avatar
    Sep 2011
    Cyprus, in the Med
    Hi guys,
    I'm a new member and new RED user and really excited about this powerhouse of a camera!
    From reading around the forum its my understanding that the EPIC has a native ISO of 800 http://reduser.net/forum/showthread....40-Mysterium-X...
    Gathering information over the past few days, it seems to me that correct usage of the EPIC can be achieved by proper exposure as No.1 priority, since all else is just META-DATA.
    This relies mainly on correct aperture and shutter speed, as ISO, White Balance, and Colour Profiles are all things that can be done in post.
    And the question: Can shooting at ISO800 and keeping an eye on the histogram reliably give me a good indication through my monitor of what the sensor is actually picking up?
    (it appears new users can be fooled into thinking they have correct exposure because they lowered the ISO setting and looked at a correctly exposed image through the monitor when in fact the sensor was being over exposed therefore killing the highlights)
    Thanks,
    I hope I'm not asking a very silly question ;)
    Quote Originally Posted by John Smyrnios View Post
    THis is sure to be a hot thread.
    Since I was just asked this about an article I wrote on R1 MX exposure over a year ago. I will post the same asnwer here:
    "how does that (ISO vs. EXPOSURE) pan out exactly related to your base stop?"
    This depends on where you set your mid grey but as a rule when highlights clip they are gone, there is much more DR in the blacks than in the top end (though I am hearing that on EPIC the TOP END has MORE thatn the R1 MX.
    "is it best to set it at 800 for both int and ext and just ND it to hell or adjust accordingly?"
    Red recomends that the the ISO be set to 800.
    I tend to do the following.
    -I always set the ISO to 320 and light accordingly looking at the histogram for cliping, etc. I always rate the camera at 320. M, MX, or also EPIC (when I get it)
    -If i want to protect highlights on exteriors then I set the ISO to 500.
    -By doing this you are effectively "stopping down" to ensure that you do not over expose the shot and protect highlights.
    -It depends on your level of comfort, if you know the sensor and the camera and you expose to the right you get great shots at 320, but you leave little room for margin of error.
    -I always monitor the RAW file and I set the Color temperature to 5000 (the sensors native setting) so I see exactly what the sensor is seeing.
    -I find the the sensor likes more light so I expose to the right.
    -When exposed properly with a lot of light it looks best.
    -Starve it from light and you can count on more noise.
    -I try to stay away from noise.
    The only other person I know who leaves teh camera a 320 all the time and monitors RAW is MArk Toia.
    800 ISO is the safe way to preotect highlights.
    I think the sensor perfroms better when you hit it with more light and expose to the right as much as possible, giving you the most amount of play in post.
    I equate it to recording a low audio signal, the more you boost it the more noise you also boost.
    Let the games begin...
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
    Jan 2010
    Sydney, Australia
    Hey don't forget about me David. I only ever shoot 320 ISO also!
    At 320 you can push the hell out of it if need be.
    Adam Eden
    __________________________________________
    Epic M 8xx, Epic X 25xx
    Steadicam and heaps of cool sh*t
    Quote Originally Posted by Adam Eden View Post
    Plus 1 for the 320 ISO crowd. Let's face it. More light makes better images and usually sharper. Rating at 800 means less light on the sensor.
    David
    Senior Member Damien Molineaux's Avatar
    Geneva | Switzerland
    Quote Originally Posted by David Battistella View Post
    David
    +1 for ISO 800, as that means protecting your highlights, and the darks are so clean, this gives you the most latitude, er oops I mean dynamic ;-) !
    Damien
    www.c-sideprod.ch
    camera rental and post services
    www.earthling-prod.net
    filmmaking around the world since 1999
    Sep 2011
    Cyprus, in the Med
    David
    Thanks David, are you still talking about the Red One sensor or the New M-X on the EPIC? I'm currently working on the EPIC and it appears to be more sensitive than the old sensor of the Red One.
    RED MX and EPIC share the exact same sensor.
    I am refereing to the MX sensor.
    RED reccomends ISO 800 but there are a few people (like myself) who like to rate it at 320 whenver possible. This will carry over to EPIC for me and I base that only on trusting TOIA becuase I do not have mine yet.
    Also, I hihgly reccomend shooting some stuff and running iit right through post.
    There are other consuderations. 320 will almost always mean short focus, getting F4 at 320 is a lot of light. F4 at 800 less light, so it might let you go to F85.6 or F8 for deeper focus.
    It depends on the situation. I'm talking optimal here.
    There is always plently of room for creative choice, budget consideration, speed of set-ups, size of crew, etc.
    320 is fine, 500 is fine, 800 is (can also be) fine. Just know the tool going in. The MX chip (RED ONE MX AND EPIC) is much cleaner in the blacks over the original RED ONE M.
    David
    Senior Member John Marchant's Avatar
    May 2010
    Normandy, England
    I tend to shoot at 320 as I usually judge exposure visually rather than technically. Rating at 800 I find I tend to watch highlights like normal and consequently waste latitude on highlight safety I needn't have worried about, at the expense of shadows that could have been better...
    My business partner shoots 800, but exposes more like video... (He's from a video background, I'm from a 35mm stills background) I usually do the grade, and knock his stuff back to 320 as a starting point for an easier curve. Everyone has their own style :)
    Epic Monochrome UK/EU Rental - rentmonochro.me
    Check out our showreel or talk to us @kippertieltd
    EPIC-M #549 EPIC-M MONOCHROME #1649 EPIC-X #3038
    KipperTie
    creative media for business
    REDuser Sponsor Brook Willard's Avatar
    Burbank, CA
    I leave the camera at 800 ASA 100% of the time. I feel that it gives you the most balanced readings of what your image is actually going to look like.
    Here's the thing - all cameras have a "native ASA" that differs from the settings we choose. Whether it's an HVX or a DLSR [stills or otherwise] or an F35 or an Alexa. The cameras all have a native ASA that is lower than what we see.
    On all of those cameras when you select an ASA [or equivalent setting] you are essentially choosing which LUT to view. It's an oversimplified description but that's what it is. Even when you choose 100 ASA on a still camera you take the shot and end up with a picture that is "meant for human consumption". It looks good. Lots of math has gone on behind the scenes to make sure that the image you see looks as a human might expect it to.
    The same thing happens in the Epic. When you turn the camera on... you see a pretty picture. It's based on the math that happens in between the sensor and your eyeballs.
    The difference with the Epic [and R1] is that you can essentially turn all of this off. You can choose a LUT that is not "meant for human consumption" but is instead more appropriate for robots. You could take all settings back to their defaults and load your data in linear. Or any number of other LUTs.
    I view this as an enormous advantage. On a whim I can pull back the curtain on my footage and see the wizard hiding behind it. Properly understanding the relationship between RAW data [and proper exposure of a RAW camera] and the infinite number of ways by which you can process footage is key to getting the most out of your camera and footage.
    Many people take this in the opposite way. "Well, the R1/Epic isn't really 800, it's actually 320. They just boost it to 800." In many ways that is true. The thing that people skip over is that EVERY camera does this. Every camera has an inherent sensitivity which is modified into a functional sensitivity via math that happens behind the curtain. The reason that people often brush over this point is because they don't realize that to be true. No other camera [in my hands-on experience] has the ability to strip back the inherent math/LUTs to see what the image "really" looks like.
    Unfortunately the knowledge that the sensor is "really" 320 [just as the M sensor was "really" 160] is a dangerous fact without a greater understanding of the RED/Epic system and RAW capture in general. It's a flash headline on a low-rent blog that is hunting for traffic. The functional ASA is what people should compare between systems.
    I interpret the Epic's functional sensitivity to be 800 ASA.
    +1 to everything Brook said.
    I also leave the EPIC at 800 all the time. You can shoot 320 with it, and some people do, but I've found ISO 800 to give the most balanced response. And I suppose that's why RED has picked it as the target sensitivity. If you can over-light a scene and not blow your highlights when rating at 320, then good for you... However, there's a good chance you're crushing out some potential DR in that scenario. But this really comes down to each shot and lighting setup.
    - Jeff Kilgroe
