Thread: Red Station Esata vs FW800
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1 Red Station Esata vs FW800
    anyone know an approximate speed difference between connecting a Red Station with eSata versus connecting with FW800 and copying footage from 1.8'' SSD to 2.5'' sata drives
    Senior Member sergio arguello's Avatar
    Aug 2008
    Buenos Aires,Argentina Los Angeles
    dont know exact numbers but night and day!!! sata is exponentially faster!
    sergio Arguello:
    Epic-M 459,Epic-X 751
    RED Rocket™™™
    sergioarguello.net
    San Diego, CA
    For me FW800 usually tops out around 2.4GB/min (less with a daisy chain), eSATA easily runs over 5GB/min. So, 2X faster at minimum.
    Cheers - #19
    Apr 2008
    Washington DC Metro Area
    Well, let's look at the marketing numbers.
    Firewire 800 is 800Mbps.
    The Red Station uses eSATA 2.0, which is 3Gbps or 3000Mbps.
    800<<3000
    So there you have it ... use eSATA whenever possible.
    Its a trickier thing when you consider eSATA 2 versus USB 3. eSATA 2 is slower, but its also more efficient. So, even though USB 3 is faster on paper, in practice I'd expect eSATA 2 to be faster.
    Of course, there is eSATA 3 which I think you can expect to find in the next Red Stations. That is 6Gbps. Oh and Thunderbolt ... that's 10Gbps full duplex. (So, you can read at 10Gbps from a Thunderbolt device and write 10Gbps to another Thunderbolt device on the same chain.)
    Alexander Ibrahim
    Director & DP
    editing/color correction/compositing/effects
    http://www.alexanderibrahim.net
    http://www.zenera.com
    Senior Member jimhare's Avatar
    Sep 2007
    Sydney Australia
    But how in the Hell do you get eSata into a Mac running a rocket, quadro, BM and video card with no Cubix?
    I guess we don't.
    Isn't there a way to get a single eSata connection on a mac pro without using a card
    Apr 2008
    You can run an eSATA extender cable from your second optical drive port to the back of your Mac.
    So ... if you have two Quadro 4000s, you can have five panels available at the back. THen you can attach the eSATA extension to the same slot as a Quadro 4000, plus keep your Rocket and BMD card.
    Of course, with Thunderbolt coming to the next generation of Mac Pro and the Red Stations ...
    Alexander Ibrahim
    Director & DP
    Sep 2007
    Sydney Australia
    Cool! So as simple as getting an extension eSATA cable and ditching the second DVD-R? That sounds worth pursuing.
    Thanks!
    Jim
  10. #10
    Senior Member Tim Whitcomb's Avatar
    Jan 2009
    Portland, OR
    Jeff Kilgore had a work around that involved running cables out the side of the MAC. so he bought an extra side panelt drille a hole and lined it wit rubber and voila. Then when its time to sell the mac he
    will put back the original side panel so as not to void warranty. I think he actually ran the BM HDMI out the side. so it didnt take a slot.
    Kind regards,
    Tim Whitcomb
    Filmmaker
