Click here to go to the first RED TEAM post in this thread.   Thread: EASY EDITING RED original FILES
Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
  1. #1 EASY EDITING from RED original FILES
    Banned
    Jan 2007
    Paris, FRANCE
    Dear Rob, Jim, Graeme, Stuart,
    Thank you in advance for the camera and we know that it is not
    enough to create films.
    We need to manipulate the files created by the Red camera
    with the ease of DV editing in FCP.
    Later, we will we change color, crop, adjust, filter, change formats for distribution, sales, printing.
    BUT FIRST we need A SIMPLE WAY to edit those files.
    Why should we first transfer to some lower quality or heavier medium ?
    The original has full qualities and is not heavy, what prohibits editing ?
    Thank you
    DV is only easy NOW. If you were editing DV back in 96, it wasn't easy.
    4k will get there, but not at the moment.
    How long do you think it will be before a 16 core Mac with 32 GB of RAM becomes as affordable as a Quad core?
    Banned
    Jan 2007
    Paris, FRANCE
    Quote Originally Posted by Thomas Mathai View Post
    I slighlighty disagree with you, DV, back in 97 was easy to edit, there was no transfer to be made first. Maybe some help of Promax helped, this is true.
    And if you speak about affordable, after spending $+-30.000 (+ lenses) for acquisition of those delicious 4K wawelets, i sure am ready to buy something to EASE work and not to go back to the dark ages ( I did negative cutting
    in my youth and two inchs editing tapes with scissors but these days are over) THINK SIMPLE ( i know this is complex !)
    Quote Originally Posted by LEON View Post
    I think you might be misunderstanding the workflow a bit.... it's nearly exactly what you are indicating.
    Open RedAlert (or in future RedCine) and generate (nearly instantly) QT wrappers. Edit to hearts content in FCP. It's that simple. If you want 4k, sorry, no FCP right now, but I assume it's coming in the future.
    Since there are precious few outlets for 4k right now, it is more practical to online or conform/master to 2k. The nice thing is that your FCP edit can generate an EDL to be conformed to 4k at a later date when 4k becomes distributable. Just import the EDL into Scratch and you're good to go.
    regards,
    jt
    Jan 2007
    Melbourne, Australia
    The same thing that held back FCP from cutting HDV natively - the decoder couldn't function in realtime to the performance degree demanded by FCP. In simpler terms - the decompression was too slow. It will get quicker. Just as FCP will quite happily chew through HDV on most systems these days, it will chew through 2K REDCODE RAW - but not until the decode gets much faster!
  6.   This is the last RED TEAM post in this thread.   #6
    Hi Leon,
    I'm not following you at all. You can drop the QuickTime reference movies straight into Final Cut Pro 6.0.2 (supports RT integration) and up.
    These directly decode from the source files. Am I missing anything?
    ROBCODE Santa Claus @ RED
    "You get the chicken by waiting for the egg to hatch, not by smashing it with a hammer" - Jarred
    Back in 97, there was limited options for native DV capture.
    There was MotoDV which barely worked if you didn't have your configurations right.
    Premiere was still at 4.2 and even Premiere 5 was clunky with DV.
    The only workaround was to capture through an analog breakout box into an Avid, Media 100 or similar system.
    I cursed Premiere a lot in those days.
    Final Cut Pro was still being developed by Macromedia as KeyGrip.
    Quote Originally Posted by Rob Lohman View Post
    Hi Leon,
    I think he means editing the native r3d files.
    Banned
    Jan 2007
    Paris, FRANCE
    Hi Leon,
    Yes, i did not express clearly enough, I wish I could edit from the
    ORIGINAL NATIVE RED FILES.
    Yes, i did not express clearly enough, I wish I could edit the
    You will be able to in FCP in the future, at least that's what the apple website said. Give it time.
    Paul
