Click here to go to the first RED TEAM post in this thread.   Thread: RedcineXpro rendering greater then 2gb files to SAN
Results 1 to 8 of 8
  1. #1 RedcineXpro rendering greater then 2gb files to SAN
    Quick question:
    Is anyone using RedcineX(any version) to render to a SAN quicktime files larger than 2gb..?
    I used to use DNxHD 36 or 120 for ofline so I never noticed this didn't work for me (the files).
    thank you
    Michael L
    PS it is dificult to realise it dosn't work as the files are finished and play they simply are not the correct lenght.
    Banned
    May 2007
    Is the disk you're exporting to FAT32?, if so, that may be your problem and you should try exporting to an NTSC drive/ or OSX Format
    Last edited by conrad gaunt; 10-18-2011 at 04:38 AM. Reason: inserted a question mark for clarity
    Quote Originally Posted by conrad gaunt View Post
    No the San will be XFS underneath and will have no FAT32 like restriction. NTSC drive?? not sure what you mean..
    EDIT actual I'm guessing you mean NTFS? or HFS?
    Senior Member Kaku Ito's Avatar
    Feb 2008
    Chiyoda-ku, tokyo
    AFS would have issues to render out larger than 2GB size because of the QuickTime API used in RED SDK. Properly set up XSAN wouldn't have that problem I think. I used MetaSAN before and remember it worked.
    Kaku Ito
    rawesome! Equipments
    RED Epic-M, RED Epic-x, RED ONE MX x2, RED ONE Mysterium, Allstar A-mount, Epic Canon Ti Mount, 1.8' SSD modules, RED PRO Prime Set (18 through 100mm), various Nikon and Zeiss Lenses, 17-55mm RED Pro Zoom, 18-85mm RED Pro Zoom, x2 RED ROCKET, Mobile Rocket, DaVinci Resolve, Cubix, GTX-285, Quadro 4000, few Mac Pros, few MacBook Pros, Sony BVM-D24, Panasonic 65 inch Series 12 plasma, Calman with Klein probe.
    Rawesome! One Stop RAW Visual Production Service
  5.   Click here to go to the next RED TEAM post in this thread.
  #5
    Red Team
    Sep 2009
    Irvine, CA
    Can you try the Quicktime (Exp) preset format? It exists for this reason.
    David
    Will do.. Thanks!
    David....
    A little feedback:
    We tried Quicktime (Exp) and at first it looked good........ BUT there was coruption on all files beyond a certian piont (3min 7sec with DNX185x)and quite a few of the files had no TC at all..
    Will work arond for now but happy to feedback more if you need.
    Michael L
  8.   This is the last RED TEAM post in this thread.   #8
    Red Team
    Sep 2009
    Irvine, CA
    Thanks for the feedback, I'll take a look.
    David
