Click here to go to the first RED TEAM post in this thread.   Thread: Sound Devices PIX 240 ProRes/DNxHD Video Recorder with EPIC
Page 41 of 41 FirstFirst ... 313738394041
Results 401 to 407 of 407
  1. #401
    Nov 2011
    Brooklyn
    Quote Originally Posted by Nate Clapp View Post
    just an fyi before you feed audio directly into a PIX rather than the camera (any camera in this case, not just RED cameras) you will need to determine the audio offset. Usually the SDI video stream is slightly delayed compared to the audio going into pix directly. Also in many cameras, the audio coming out of the camera's SDI stream is offset (earlier) than the video stream. Sony F3 and Epic (but on previous build, each build needs to be tested to be sure) both do this, as well as many others. My testing with a now obsolete Build 3.0.0 was 80ms if audio is coming off SDI from camera (Epic) or 150ms if you feed audio directly to pix. also I set TC offset +1 so TC on pix and epic are frame accurate. good news is this can be saved as a setup file and loaded into pix when you use that camera, and everything will be exactly in sync. every new firmware suggests you should check whether everything is still valid.
    WOW. Super informative. THX
    ___________
    Nick Morrison
    Director, Producer, Writer (WGA-East)
    ASTRONAUT (Partner)
    www.astronautnyc.com
    www.nickmorrison.tv
    ASTRONAUT CAMERAS: Two Scarlets
    LENSES: Contax Multi-Cam Prime & Zoom Set (Leitaxed and RP Cine-Modded)
    POST: Avid Symphony Edit Suite, RRocket (x2)
    Senior Member A. Clint Litton's Avatar
    Nov 2007
    Brooklyn, NY
    Quote Originally Posted by N_Villers View Post
    The Pix would be perfect if it showed thumbnails of recorded media for playback.
    +100
    The PIX has come so far since its release...lots of fantastic improvements to monitor viewing quality, feature set, etc. My biggest gripe is lack of thumbnails when perusing recorded clips, as searching by clip name is almost never what I'll remember about a given take. Perhaps this could be something in the works?
    Between the great things we cannot do and the small things we will not do, the danger is that we shall do nothing.
    - Adolph Monod
    www.clintlitton.com
    www.obpfilms.com
    Senior Member Esmaile Neissi's Avatar
    Dec 2007
    Australia / Irland
    Sound Devices have a perfect customer service great company
    Senior Member Zack McTee's Avatar
    Oct 2011
    NYC
    Quote Originally Posted by Nick Morrison View Post
    Does the drift apply if you are running audio via SDI? or just when you are running audio via xlr directly into the pix?
    - zack
    Zack McTee
    zackmctee.com
    twitter.com/zackmctee
    Senior Member Nate Clapp's Avatar
    Sep 2007
    Wash, DC
    Its not drift it's offset. And yes if you read above there are different offsets depending where the audio is coming from. Most any camera is going to feed video later than audio that is fed directly via xlr into pix. If audio is early on sdi stream then that is a camera "flaw" but many cameras have it. Good news is it is easily correctable in pix, or if you prefer, in post.
    Braunschweig, Germany
    It is easy to correct in the PIX. The Aja KiPro Mini shows a similar offset, but it doesn't offer such a correction (or I didn't find it yet).
    Regards,
    Uli
    My Red is called Vertov after a Russian avantgarde filmmaker, a pioneer in modern cinematography, a true revolutionary who later suffered under Stalin's bureaucracy.
    Jan 2011
    Berlin, Germany
    Did anybody see the pix 240i yet?
    Is the new display worth the extra bucks?
    Thanks for sharing!!
    Scarlet-X #075 "Arletty"
    RPZ 17-50mm
    Angenieux 35-140mm T3.5
    Vantage 14mm T2
