Thanks so much for this. Incredibly helpful.
hey man ... its been discussed to death on here and dvxuser and the same discussion always turns up whenever there is a thread that has the phrase crop factors in it. There are minor, very minor inconsistencies with field of view because of the physical nature of constructing lenses but these inconsistencies don't detract from the fact that a 50mm is a 50mm is a 50mm no matter whether is a full frame prime, an aps-c zoom or even a micro four thirds 50mm. The only difference is the size of the image circle and therefore the size of sensors that they can cover. Its the sensor size that changes the field of view - not the focal length.
Best thread ever!
How about a 2,5K Super 16mm mode?
I think this would cater the indie market quite nicely. Lower data rates and such and a Super 16mm look (which some people might actually prefer).
While we're at the topic. Is it physically actually possible to mount a Super 16mm lens to the Scarlet X? Or will it result in backfocus issues?
My expertise in that area is limited at best.
David Rasberry has pointed out that the 2k crop factor was a bit off. I have since corrected that. Thanks David!
Correct. The lens properties don't change in any way, but the field of view or cone of vision available to the shooter has been reduced because of the smaller the sensor size on a given focal length. It's literally cropped off, hence crop factor.
Above is not correct (at best not complete) by any strech of meaning.
FOV is according to mathematical and physical laws dependent on BOTH the sensor size and focal length used during recording. (I'm not talking about only one lens but multiple lenses)
Of course this difference in our expressing of FOV could be semantics due to different starting points in the thought process.
For example I consider this as a correct way of expressing the FOV laws:
1. I have only one prime lens of i.e. 50mm and I could record on Scarlet in different windowed/cropped modes.
2. Only the (active) size of the sensor is changing the field of view, not the focal lenth
Stating only sentence 2. without the 1. is not correct because someone reading it could be led to believe that whatever focal length he uses (20mm or 80mm) he would always get the same FOV as long he always shoots at i.e. 4K.
If we forget about the sensors I still believe that APS-C 50mm lens (diagonal FOV 30°) has a considerably different FOV than FF35mm 50mm lens (diagonal FOV 47°) (i.e. if we project them on the piece of paper.)
Of course if you use a sensor that is smaller than the projected image of APS-C lens, then the recording from APS-C sensor will show the same FOV for the FF35mm and APS-C 50mm lens.
The other way around, if you use a sensor (FF35mm) bigger than the projected image of APS-C lens, then the recording from FF35mm sensor will show wider FOV for the FF35mm than for APS-C 50mm lens. (difference will be due to vignetting)
Phil, sorry to sort of derail your effort. I'm actually just "learning in-depth" the FOV facts and would like someone to confirm or dismiss (with valid arguments) my thoughts on this.
Anyway thanks for your efforts - you prompted me to demystify (to myself) the crop/FOV theme.
Okay. Time to simplify all of this. I'll be adding the following graphic below to the head of this thread as I want to clarify any confusion going on regarding crop factors and their effect on FOV with the same lens.
This graphic shows different sensor sizes/Red Scarlet X Recording Formats with an aspect ratio of 1.9:1 captured with a 50mm lens. I've calculated the approximate field of view of a 50mm lens on a FF35 sensor cropped to 1.9:1 (Red's sensor standard for Scarlet X), which is 44.3 and not 47 due to the 3:2 aspect ratio. I've added the calculated FOV and the "equivalent" lens that you'd use on a full frame (8-perf) to emulate that frame if shot from the same distance.
It should be noted that all of this is approximate based on a single lens measurement and single focal length. Manufacturers often drift a bit in terms of what the actual focal length of a lens is. There are several 40mm lenses out there that are closer to 41mm and 43mm.
Hope that helps.
****Edit I should also add that the Data Sheet has been updated to reflect the crop factor 3.24x for 2K. Make sure you refresh or download the new one.
I'd like to nominate Phil for a raise. Any second?
That is awesome Phil. I "get it" now.
Hi Phil, I thought I had it until you added this on the 1st page referring to the Gas Mask man with the orange flower.
"For instance if you wanted to shoot this same frame 4k at 80mm and then capture some slow motion 2k from the same spot you'd use an 162mm lens, which would likely only exist in a zoom."
Maybe I read it wrong.
