Click here to go to the first RED TEAM post in this thread.   Thread: Weird Color RGB difference in my Red one X footage
Results 1 to 5 of 5
  1. #1 Weird Color RGB difference in my Red one X footage
    Junior Member
    Mar 2010
    Florida
    Forgive if this is an obvious topic.But i need Help, please.
    I use a RED One camera.
    Just made a sensor upgrade to Mysterium X .
    I have some 4k cf card footage that i have imported in Redcine X and Final Cut 7.
    In REDAlert yellow as well but I can change the ColorSpace to RGB and it is done.
    In Redcine the color temperature is ok and RGB is fine, but in Final cut all footage is yellowish.
    Way too warm.
    Please tell me What should I do to import in Final Cut with correct RGB.
    RED ALERT is OLD, deprecated software that is no longer supported and it does not have proper color support for the MX sensor. You need to be using the latest Final Cut Pro plugin and the latest version of REDCINE-X (instead of RED ALERT). This will clear up the yellow color issue.
    Everything is downloadable from RED.COM/support
    - Jeff Kilgroe
    Forgive me for asking an obvious question, but are you rendering your footage out of Redcine, or just checking it there? And then pulling it into FCP via Log and transfer or god forbid, the proxy method. Your workflow is just a bit fuzzy, at the moment for me to be of much help.
    http://www.post-holes.com
    http://www.leadingedgevideo.com
    Philip P.
    High Point, North Carolina
    Red # 964
  4.   This is the last RED TEAM post in this thread.   #4
    Use latest REDCine-X (or REDCine-X Pro) - don't use REDAlert as it doesn't understand M-X sensor.
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    Junior Member
    Mar 2010
    Florida
    Thank you for helping.
    I am using Redcine X and it understands My RedX footage.
    Red Alert is an oldie, I know.
    But in my workflow I think , what I did wrong was importing the files directly to FCP , from an HD , not using Log and Transfer.
