Thread: Scarlet ISO's and Noise
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1 Scarlet ISO's and Noise
    Jan 2011
    There's common talk on the web about the Scarlet X being noisy past 800 ISO and something about the 800 being the "Sweet Spot". I'm wondering if someone can confirm the ISO capabilities especially in low light please.
    Senior Member Les Dittert's Avatar
    Sep 2011
    I would like DXO labs or imaging resource to put the camera to test, as if it was another still camera.
    -Les
    Jan 2011
    Quote Originally Posted by Les Dittert View Post
    -Les
    A test, some low light footage at various ISO's would be good. Since the Scarlet X has the same MX sensor as the Epic, i'm wondering where these users who are commenting on the ISO's get their info from
    Nov 2009
    A good way to look at it is "How do I expose my films"
    There is a goalpost on the left side of the histogram that tells you how much of the frame is "noisy" - there is also a similar goalpost on the right for overexposure that tells you what is clipping.
    Generally if you are in between the goalposts you are "good". I've rated things up to ISO 2000 on the MX sensor - and this was before 16 bit depth of Scarlet and Epic.
    If I have time I will post an example of how this all works.
    If you turn the camera on, point it at something and shoot at ISO 2000 and then bring it into the computer and render it out without adjusting your curves or anything then you might be "unhappy".
    Scarlet and Epic are cameras that let you work with a "Digital Negative". Half of the process is the PROCESSING of the digital film to yield the results you are seeking.
    Its not One button kind of "video" shooting.
    Hope that makes sense and helps.
    Jan 2011
    Quote Originally Posted by Dan Kanes View Post
    All the info is appreciated. There is no doubt that a lot of footage has to go through the "processing" or "grading" stages.
    When the Red and then the Epic came out, there were various tests and footage posted proving how well the camera's performed under low light situations especially night time, and the classic signature footage of the lit candle and cigar at various ISO's including 3200 ISO
    I was hoping to see something similar with Scarlet.
    Senior Member jimhare's Avatar
    Sep 2007
    Sydney Australia
    At the same ISO and compression level, Scarlet and Epic should be identical.
    I've used the Epic for several weeks now and it is incredibly clean, espeically coming from the M sensor and being rated at 320 for so long, I found it incredibly refreshing.
    Yes, it is not difficult to introduce noise in some situations, but there is no set rule such as "anything above 1600 will be noisy." Every situation is different and you may find you get noise at 1200 in some situations and don't get noise at 2500, all depends on the environment so be careful not to make any across the board decisions about what the camera does as there are so many variables involved.
    Norway
    Download the exposuretest from here, adjust the ISO and see what you find...
    http://www.reduser.net/forum/showthr...th-a-Scarlet-X...
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    Senior Member Nick Pasquariello's Avatar
    Dec 2010
    Providence, RI
    The ISO on Red Raw files is metadata. You are not actually adjusting what the sensor is ingesting by increasing or decreasing the ISO, only how that raw data is being processed and displayed.
    This isn't an abnormality. With film stock, you can only change your ISO if you physically use different film. With digital cameras, you can only truly change the ISO range of the sensor is you physically change out the sensor system (which is not practical). But since you can *kinda* change the ISO by changing the metadata of how that sensor input is changed, all digital camera manufacturers allow you to do that. But you still aren't changing what the sensor sees, just how it is interpreted. The sensor still has the same maximum and minimum light response points.
    Red, however, is just more open and upfront about this, since they give us access to the Raw data and raw metadata.
    800 will always be your sweet spot for the MX sensor, with about 6.5 stops in either direction (both brighter and darker) that read correctly.
    Norway
    Twitter: gunleik
    Jan 2011
    Thanks for all the helpful info guys, i guess you can never rid of all the haters out there towards Red and misrepresenting the information. Looking forward to it.
