Thread: Projection Help
Results 1 to 4 of 4
  1. #1 Projection Help
    Jan 2011
    Memphis, TN
    To start I have very little experience with projecting footage. I’m starting to move into bigger markets and have run into a bit of a snag.
    I am testing some footage at a local theatre and the manager told me that I need to have a “DCI compliant hard drive” for it to work. I’m assuming he is not a tech guy and actually meant DCI compliant footage. I’m trying to get the make and model of the projector and will post it as soon as I get the information.
    The footage was shot RED ONE 4.5k and now sits in 2048x854 Pro Res 4444. What do I need to do to get this to project? Cineform?
    I know there are plenty of big dogs on here that will instantly know. So many thanks in advance.
    RED ONE, SCARLET X,
    EPIC Coming Soon.
    Jan 2011
    Memphis, TN
    Ok as an update the projector is a Barco DP 3000. The projection will be fairly on a fairly small screen as far as theaters go.
    RED ONE, SCARLET X,
    EPIC Coming Soon.
    Jan 2008
    Actually, your hard drive will need to be formatted correctly AND your footage will need to be in a compliant DCP form to playback. There is quite a bit more to it than just supplying a file on a drive. There is a long thread regarding DCP authoring on here, but sufficive to say it's quite a bit more work from where you are at now to get a set up going that will work. i'll let those who have done this chime in.
    Jan 2011
    Memphis, TN
    I’ve been doing a lot of research. Has anyone had any experience using this plug in: http://www.qubecinema.com/products/Xport
    It seems like it might be a good alternative to doing it the traditional way.
    RED ONE, SCARLET X,
    EPIC Coming Soon.
