Thread: DaVinci Resolve Keyboard - Cheapest control surface
Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 82
  1. #21
    Senior Member Rosario Balistreri's Avatar
    Apr 2011
    Rome (Italy)
    Quote Originally Posted by John P View Post
    What is the model name of the trackball/trackpad you are using? Can you please post a picture of this? Thanks!
    I'm using the Apple Magic Trackpad
    http://www.apple.com/magictrackpad/
    Junior Member
    Mar 2011
    Would any other trackpad work, have you have tried any other? What is the model name of your keyboard?
    My maximum monitor resolution is 1920 X 1080. Will your program support this? Thanks.
    Apr 2011
    Rome (Italy)
    Every trackpad works, If you can use it as a mouse, you can use it with my script.
    My Keyboard is a 15$ Mediacom keyboard, the exact model is CX7710.
    I've also made a working setup for Luis Otero with his Logitech Keyboard.
    Yes, now every resolution from 1680x1050 to 2560x1600 is supported.
    Apr 2011
    Rome (Italy)
    Here is a fast made video showing some functions... I'll show you everything else with a better made video ;)
    ah, and the website is online now ;)
    http://rosbalistreri.netsons.org/?p=Keyboard
    That's pretty sweet. Could your script be used with an x keys panel? I would assume so since the x keys cab be mapped to any keyboard command.
    I would like to use an x keys panel with my euphonics control surface to have a lot of the functionality of the resolve panel.
    Tim
    Local 600 DIT
    My Personal Portfolio:
    www.sutherlandprojects.com
    Apr 2011
    Rome (Italy)
    Quote Originally Posted by Tim Sutherland View Post
    Tim
    Sure! I've not a xKeys panel so I can't configure it for you, but I can help to replace the "keyboard" blocks to yours.
    EDIT: 1.0 version is out! Fully working now!
    Now i'm making better stickers and then the PDF guide ;)
    Senior Member Doug Beatty's Avatar
    Aug 2011
    I couldn't find the Mediacom CX7710 keyboard available on eBay or from any US vendors on the internet, but I did find an almost exact (and cheap) model called Anyware Ez-IKE-101 that would do the trick.
    Oct 2008
    Gorham, Maine
    Would a trackball work?
    David Fuller
    AirStream Pictures
    RED ONE #172MX
    EPIC-M #1053
    Apr 2011
    Rome (Italy)
    Quote Originally Posted by Doug Beatty View Post
    It seems perfect!
    Quote Originally Posted by D Fuller View Post
    Sure!
    The x keys Mac osx software can be downloaded and configured without owning the device. If you could do a quick test and see if I can retain main keyboard functions and map the x keys buttons to your script, I'll be glad to send my money your way.
    This is the x keys I want to use:
    http://www.piengineering.com/xkeys/xkpro.php
    and here is the software:
    http://www.piengineering.com/softwar...rollermate.php
    Tim
    Edit: I just saw on your site that you already used controllermate, so setting this up should be a breeze.
    Edit 2: since I have the euphonics surface, I'm more interested in the navigation and node mapping/creation buttons than most of the knob and track wheel replacements. The things I want to do with x keys are mostly hard buttons on the davinvi panel since the euphonics already does a pretty good job with the knobs for adjustments and selection and play controls.
    Local 600 DIT
