Best most natural grade thus far. This frame looks really nice. Awesome job Brandon!
Did I miss the videos of the brown, cardboard boxes being opened?
Thanks John.
No video of that was made Arnold ;)
Below is a short video clip of one of the shots I posted a still from. I'll be posting a second longer video clip of a different shot soon.
I shot the wide landscape shots below yesterday and I was really not pleased with the results. LOMO lenses are amazing for people and faces. I love the results I am getting with these types of shots. But for wide shots, especially where there is a lot of detail (e.g. trees) the quality is just not there. My plan now is to rent proper cine glass, master primes or ultra primes, for the wide establishing shots I need and shooting the rest with the LOMO lenses.
LOMO 35mm wide open (T1.7). A quick grade in Premiere Pro CS 5.5.
I accidentally uploaded a version of this shot with some bad image stabilization. Here it is without any.
Are you always shooting wide open? You might get a much sharper and more precise look for your wides by shooting at a higher T-stop.
It might be worth checking the lens collimation too, sometimes, the closer to infinity these lenses get, they can get soft - this combined with wide open shooting might be giving you the softness you don't like?
Getting the lenses checked out would be a wise move before starting on your feature - and may save you having to rent lenses :)
No, not always. I'm not wide open on any of the wide shots. In fact I'm fully stopped down on the first ones I did (T16) and was even then overexposed. I will get the lenses checked out because they are soft at infinity like you describe. Thanks for the advice!
No problem :) You may want to shoot some test charts to confirm where your focus goes soft. Another thing that might be slightly 'off' is the OCT19 to PL conversion - a mm can be a big distance on a lens.
This remounting, if not done really well, often ends up in loosing infinty focus... so it might be a case of shimming or re-mounting... but again, if this helps get your set working fully, I think you'd be better off shooting the whole project on the same lenses. It'll have a consistent look and make grading simpler.
Keep updating and enjoying your tests ;)
Also don't forget by stopping down past about f/11 you're going to have softening from diffraction. That could be part of the issue.
Andy, I do have a lens chart, but haven't shot it yet. I will do it this weekend. I'm also going to try to find someone local that can test, and if need be service, the lenses. Thanks again for the help.
Harrison, I didn't realize that. I will definitely look into this as well. Thanks.
