Click here to go to the first RED TEAM post in this thread.   Thread: 1 FPS Timelpase, Galaxy Of Hot Pixels and Sensor Calibration Times
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 1 FPS Timelpase, Galaxy Of Hot Pixels and Sensor Calibration Times
    Senior Member Miltos Pilalitos's Avatar
    Jan 2007
    Athens, Greece
    A few hours ago I shot a couple of night exterior Time-lapse shots with the EPIC. FPS and shutter were both at 1fps.
    While on location, everything was looking good on the LCD screen but when I viewed the footage later on RCX, hundreds of hot pixels where visible. In fact, there were so many that the footage is rather unusable! Fortunately, it was only a test so we didn't have any heart attacks. Nevertheless, I was surprised by the obviousness of the problem. It's been a while since the last time I shot a time-lapse with the RED ONE and I was under the impression that RCX somehow masked the hot pixels when in Full De-bayer mode but certainly this is not the case.
    So, the only solution is Sensor Calibration at the time-lapse's settings. After the calibration's 20 minutes (I almost emptied a fully charged REDVOLT doing it!!!) the hot pixels disappeared and the camera was ready to shoot nice clean 1 fps Time-lapse. The question now is... what does the 1fps Sensor Calibration do to the image if we go back to normal shooting settings like 24 Fps, 1/48th? The first thing I noticed from a very fast test was that some of the hot pixels where now appearing as black when the subject was overexposed (clipped whites). This is almost a deal breaker in many scenarios so that means a new Sensor Calibration is required for the new settings.
    I am not sure why the EPIC takes so much time to do the Sensor Calibration but it can certainly be an issue if you are planning to shoot Night Time-lapses as part of a bigger shooting day. The Sensor Calibration times from one setting to the other will kill even the most patient crew! Maybe two EPIC bodies would save the day. :D
    Something to keep in mind then.
    Miltos
    www.pilalitos.com
    EPIC-X #418, RED-MX #1473, RED ZOOM 18-50, RED ZOOM 50-150, Duclos Tokina 11-16
    Miltos,
    Shoot the TL footage on the user setting and then shoot the 24fps with the EPIC default calibration.
    You actually get two calibrations.
    The default
    The user FPS calibration.
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
    Jan 2007
    Athens, Greece
    Thanks David. What if the factory settings are not matching the ones we are using for our project? Is it manually calibrated also?
    Miltos
    www.pilalitos.com
    I believe you only get one manual calibration.
    It would be nice to store two or three.
    I think the calibration time might be a bit longer due to larger sensor size, HDRX,but I'm just guessing. There is more going on than in the r1. That is for sure.
    David
    Senior Member Mike Lary's Avatar
    Mar 2011
    Seoul, South Korea
    Quote Originally Posted by Miltos Pilalitos View Post
    Hi Miltos,
    It's my understanding that, starting in firmware version 2.05, user-defined black shading calibrations are stored as presets for later use (they'll be auto-selected when you go back to those same camera settings). In theory, as long as you don't have big ambient temperature changes, you could black shade for each anticipated frame rate and then switch between them during production. Once you update the firmware, however, the presets will be gone. That's my understanding based on a conversation with support, but I haven't tested it yet.
    BTW, here's the official word from Deanan on when to perform black shading.
    Quote Originally Posted by Deanan View Post
    My recommendation is to blackshade:
    1) upgrading to new firmware
    2) big ambient temperature changes
    3) long exposure times (longer than ~1/15th sec)
    4) very short exposure times (shorter than around ~1/1000th)
    5) beginning of a project
    6) as often as you feel like
    Remember to black shade at default after long/short exposure black shade when your finished.
    More convenient/flexible black shading coming later.
    Here's the original thread:
    http://173.199.159.58/forum/showthre...en-shoot/page5
    Mike Lary
    Director of Technology, DIGITAL FACTORY, Seoul
    Digital Revolution Since 2009
    Color Correction/Digital Workflow/Red Camera Rental
    www.DigitalFactory.kr
    Senior Member Nils Ruinet's Avatar
    Paris, France
    Could someone at Red please confirm this (regarding storing more than one black cal in build 2.0.5) ? I also noticed the hot pixels in long exposure mode, and doing a black cal takes a loooong time when the light is moving and you need to get shooting.
    I think Jarred mentionned there would be an option to memorize different black calibrations at various settings, but I didn't hear anything about it being implemented in 2.0.5...
    Out of curiosity, does anyone know why black cal takes so long ? I think it was much faster on the Red One.
    I'm running 2.0.5
    Went through this two nights ago.
    1 user calibration
    1 default
    That's it under this build.
    Tested by me.
    David
  8.   This is the last RED TEAM post in this thread.   #8
    Red Team Deanan's Avatar
    Jan 2007
    Quote Originally Posted by David Battistella View Post
    I'm running 2.0.5
    1 user calibration
    1 default
    Tested by me.
    David
    Correct, two cal slots are currently available.
    Paris, France
    So that means you can store 2 different calibrations (for example one at 1/50 shutter and one at 1s shutter) and then switch between them as needed without having to go through the cal process again every time ?
    I take it to mean
    1 slot for default (because you need a default)
    1 slot for user program
