Click here to go to the first RED TEAM post in this thread.   Thread: Sound ?!
Page 1 of 13 1234511 ... LastLast
Results 1 to 10 of 126
  1. #1 Sound ?!
    Senior Member Nils Ruinet's Avatar
    Paris, France
    There has been a lot of talk about build 12, but there is one major feature that hasn't been discussed so much : Sound !
    Hasn't anybody tried it yet ?
    I just had a look at the updated user manual, and the specs look very promising. 4 inputs, 24 bit, 48 khz, uncompressed. So even here Red seems to offer more than the competition.
    Now it would really be interesting to hear what real sound guys have to say about it.
    Also, I didn't find how the files are organized. Are the audio channels embedded in the R3D file (hopefully not), or are they recorded as separate files ? WAV ? AIFF ? Is the BWAV format supported (with timecode and other metadata) ?
    Concerning the post workflow, do 24 bit files need to be handled differently than 16 bit files ?
    Thanks,
    Nils.
    Here is a quote from Red's user manual about sound (page 11) :
    Line input analog audio received via the min-XLR inputs is immediately digitized at 24 bit per sample at a 48KHz sample rate. Microphone level audio inputs are routed via an adjustable gain pre-amplifier before digitization, no gain adjustment is available for Line level inputs.
    Reference Line Input level (0dB) is 0.775v. Microphones with an output sensitivity ranging between -30dB and -60dB can be accommodated by the pre-amplifier, which provides user adjustable amplification over the range of +22dB to +54dB with minimal signal degradation.
    Due to the significantly higher precision and dynamic range of 24 bit sampling, input stage limiters or AGC’s are not provided by the RED-ONE camera. The digitized audio data can be considered as high dynamic range RAW sound information that is complimentary
    to the high dynamic range RAW video information.
    Just as linear response RAW video data is converted to REC 709 for metering, the linear response audio data is converted to Log Base 10 data for metering. A color coded 4 channel audio meter is provided in the lower section of the camera GUI. This information is visible in the RED-EVF, RED-LCD and HDMI (DVI) monitor outputs.
    The goal for optimal quality recording is to place the audio reference level at an appropriate location in the digital range, providing sufficient headroom above the reference level to prevent clipping, while maintaining the sound quality of lower volume sources such as dialog.
    A 0dB reference voltage level of 0.775V provides approximately 8dB of headroom above reference. Microphone pre-amplifier gains should be adjusted accordingly (i.e. 8dB lower)
    e.g. With an Azden SGM X1 microphone rated at -41dB sensitivity, set the microphone
    pre-amplifier to (41 – 8) = 33dB for optimal recorded signal quality.
    Milton, Florida
    I, too, am very interested in the audio on the RED as I'm not from a film background and will always do my audio via camera absent a compelling reason to do otherwise. The manual info sounds encouraging. Would sure be interested in impressions from audiophiles out there.
    Elizabeth Lowrey
    Triumvirate Filmworks
    RED Epic-X #2114
    P.S. - Visit The Chase Lounge for some of the best Sopranos discussions on the net.
    Senior Member Alexis Hanawalt's Avatar
    Mar 2007
    Los Angeles, CA
    Along with this, I've been wondering how/where people intend to mount microphones to the camera for doc work, etc.
    Alexis Hanawalt
    Bolster Camera, Inc.
    www.bolstercamera.com
    Jun 2007
    :whistling: very nice remmarkable note hope somebody test audio for us please..:weight_lift:
    Senior Member Finner's Avatar
    I can forsee capturing good sound with a red being very difficult due to no audio control pots on the camera. I think most will have to capture audio with a different device other then the camera.
    www.finnerknowsbest.com
    "There are many dying children out there whose last wish is to meet me." The HOFF
    "you'll be hearing a lot about me over the next couple of decades." The JohnathanLB
    Senior Member I Bloom's Avatar
    Jan 2007
    Manhattan
    Quote Originally Posted by Finner View Post
    It seems designed to take the line off a mixer. Which someone can surely do. We do it anyway on cameras that have pots.
    Quote Originally Posted by ibloom View Post
    Yes thats clear I guess I should have phrased things better by stating that capturing sound without a dedicated sound man will be quite difficult. Also when using a dedicated sound guy anyway it is often easier to have him record to a DAT and save cables running to the camera.
    Paris, France
    Quote Originally Posted by Cinewalt View Post
    And also, are the fans quiet enough not to interfere with such an onboard microphone ?
    I guess when it gets hot, you'll hear the fans ?
    Banned
    Are there audio adjustments you can do in the menus?
    Senior Member Anders Holck's Avatar
    Regarding the location of the Audio:
    Quote Originally Posted by Rob Lohman View Post
    2) audio is recorded inside the R3D files
    3) the only way to currently use that audio track is through the QuickTime wrappers
    4) regenerating the QuickTime wrappers in RED ALERT will *remove* the audio tracks!! A fix for this is high on the todo list for January.
    Facebook Skype: aholck
