Thread: Looking at the sensor and testing PL and EF
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1 Looking at the sensor and testing PL and EF
    Nov 2011
    www.cinema5d.com
    Here's the article: http://www.cinema5d.com/news/?p=9243 (R3D file here)
    But some excerpts:
    Disclaimer: This is not a scientific test, merely a look at the sensors qualities under the given condition.
    This is a quick test to get a feeling for the sharpness of the Scarlets Mysterium-X sensor. And to make sure sharpness is not suffering from lens type I tried some PL lenses with a Scarlet PL mount as well. More on that later.
    Setup:
    Contax Zeiss 28mm T2.8
    Recorded at 4K, ISO 800, 25fps, 1/25th shutter, Aperture 5.6 +1/2
    Under the given light conditions the Contax Zeiss produced very good sharpness and could hold up with the PL lenses. The PL lenses used were pre-production models and I cannot publish images taken with them.
    A quick note about mounts on Scarlet-X: It's extremely easy to switch back and forth between EF and PL mount. All you have to do is unscrew and screw 4 torx screws back in. Especially if you want to use PL you should calibrate your backfocus afterwards.
    Jul 2009
    Las Vegas
    Very cool Sebastian! I have Zeiss ZF's and this little test as well as Jarred's post on Peter Lik's test with the EPIC, let's me know that my glass will hold up well with the Sacrlet. Thanks for doing this test and posting.
    Michael Su
    Cinematographer/Director
    http://www.imdb.com/name/nm0836784/
    http://www.persistfilms.com
    Scarlet X #1721 "Kundun"
    Senior Member PatrickFaith's Avatar
    Nov 2011
    Northern California
    I have Zeiss Compact Primes, my scarlet order still hasn't come ... so the question is ... should I convert my compact primes to PL to increase sharpness ... or does it not matter between EF and PL as far as sharpness?
    ?I'm not a expert at this type of stuff ... so I'd say from this example it doesn't matter, i currently use zeiss cp .2 with a canon 5d, and i think i still have some time to change my order to PL(i order AL mounts)?
    http://www.youtube.com/patrickfaithart & http://Pudl.tv
    "Litl" #250 "Pudl" #397 of "Ink" (Monochrome) #3752
    Nov 2009
    Patrick, the mount doesn't add sharpness.
    Sebastian is illustrating the quality of certain lenses.
    Contax VS CP2 - my money is on contax for image.
    Nov 2011
    Northern California
    Quote Originally Posted by Dan Kanes View Post
    Cool, thanks ... one less thing to worry about then ... I think I will stick with EF since i can move my lenses back and forth to canon stuff.
    Nov 2011
    www.cinema5d.com
    Yes mine too. I did a lens test between CP.2 Contax and EF mount Zeiss glass on a test chart with all stops (which I couldn't publish because again it wasn't scientific enough, what good argument to drop tests on glass) and Cp.2 had heavy vignetting at open stops and EF weren't as sharp as Contax. CP2 were a tad sharper than Contax though.
    Something that should be mentioned here, especially those new to working with Red material, is what R3D data is and the power behind it
    The R3D is the raw image data straight off the camera.
    Much like working with Camera Raw images captured on a modern DSLR, Red's R3D raw files have a lot of resolution, color, and dynamic range that can be unlocked through post processing.
    Take Sebastian's tree R3D for example:
    Also to note, the REDCODE Compression Ratio plays a role in your captured image quality. Most large features are being captured between 5:1 and 8:1 in my experience and that produces exceptional results. That is in regards to motion capture. There could be certain advantages of shooting at higher quality REDCODE ratios for still images destined for high resolution printing depending on your own preferences.
    phfx.com IMDB
    Scarlet-X #316 "Skully"
    Nov 2011
    www.cinema5d.com
    Thanks Phil, this is very helpful.
    What are the contrasty beige and black pixel artifacts in the post processed image? Thanks
    Phil,
    You truly are a great resource on these boards and I find your posts highly educating and enlightening. Keep it up! :-)
    Erik Franzén, Director/Writer, Darkly Dreaming Team
    "It's easy to count pixels so people do it. What is important is what you do with those pixels."
    ~ Graeme
    Junior Member Luuk de Kok's Avatar
    Nov 2011
    Tilburg, Netherlands
    Thank you Phill for your great knowledge!
    Also thank you Sebastian for posting this :)
    You don't need eyes to see, you need vision.
    enthusiastic photographer and urbexer, check my flickr page here: http://www.flickr.com/photos/scarluuk/
